Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
latest update/release is bad...
no gapps will instal correct,after 63% googleplay stops.
f...ckd .p .my phone ..........
very stable, detects the language automatically, it is very smooth, but I could not correct the aboot.bin because .... do not know how someone could help me?
Yes I got the Xposed Frameworks to work a few days ago. I have posted my feedback on Nameless Rom 2.1. But the only problem is that before each restart you have to delete some files from dalvik cache or you will have bootloops on next reboot, check this link for more info. Which is a real headache so I went back to my Original Nameless rom 2.1. Just a heads up, always make a nandroid backup before trying Xposed Frameworks 5.1.
is it unusual after a OTA update to 5.1.1 for the phone to run like a slug? will it speed up after 10mins of use?
From Experience I think, after two or three restarts, it will run more smoothly. But if you are coming from CM 12 to cm 12.1, you should have start fresh for a better stable rom.
How do I full wipe? I forgot. Surely there's a few more options to check for full wipe when wiping for a clean/fresh flash/install?
Need help!
For some reason i finally decided to flash the TWRP from 1st page and lates cm12.1 with android 5.1.1. plus gapps
after succesfully flashing, my phone appear as d320, and my phone is d325, the ril is not working and the home button fuction as back button
can someone help?
Need help!
can someone help?
Flash correct aboot.bin
