Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
i have download mod and i dont have fastboot
Oh. When restoring Download Mode, bootloader automatically locks. Maybe that is why touchscreen is not working. Maybe you have to have unlocked bootloader.
But I am not sure. Try going back to stock.
nice rom,keep bumping into the same problem.
aosp keyboard has stopped , disabled it and using google keyboard for now.
I saw other users had this problem at the start of this topic,but a solution was never given.
is there a solution ?
Did you make a clean install? My stock keyboard is working fine.
Also make sure that you are using TWRP recovery.
This rom becomes more and more exceptional every day!
In my opinion, this is the best Lollipop rom.
Thanks, vm03!
please please, can someone tell me a right way to root my phone, I'm owning a LG L70 D320 and i've been trying so many ways to root it but without success, and when i see you guys here with customs rooms it would be a way to root it. And another question, before rooting it do i have to unlock bootloaders first or rooting. first? Help me because i'm not great in tech things and i really want to try Lollipop on my LG L70. Thanks to everyone who helps. :)
Use purple drake lite with pc to root your d320n, after that, install supersu from store to gain root priviledges. Then follow guides here on forum to unlock bootloader and install recovery (you'll need one for flashing roms).
What is flashing rooms, for what i need it?
How do I fix my 4G and get it to work in CM12.1? I tried the default APN's that CM12.1 has/lists and still no go. It's also being read as 3G instead of 4G. I can call and sms but my internet/web just doesn't work when I have my data enabled by itself. Web/Internet will work just fine if I'm connected to a wireless network.
Also, note/bug: It keeps crashing when I try to access "Security" under Settings. I updated to the 4-25 5.1.1 build using CM's OTA update thing.
You would need it if you wanted new features that some roms offer and upgrading to the latest android before your manufacture releases it. In some cases people do it because they don't like the stock rom. Im one of thoes ppl
If i choose to don't do this is there any problem? It seems too complicated to me?
I just update from cm 12 lates build to com 12.1 and installed gapps from here pico version and when i download something from google play it crashes at 90%.
I tried a clean install and and gapps would still crash and now my default keyboard is crashing two.
I suspect gapps is the problem can someone pleas provide a source for working gapps?
