Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
From reports. I see that it's working perfectly for some people (except the signal bar) but have heard no ms323 users try it out (since fcing). I'll try it out. I need to factory reset anyway. Somehow my 20150219 cm12 old build got currupted (expected). So I'll be happy to try this out.
Thanks VM. Without you the L70 forum would be barren with no Roms. Thanks for the device tree <3
Also people that want to choose what GAPPS they want. I would try this:
http://forum.xda-developers.com/android/general/gapps-lp-gapps-pa-gapps-aroma-installer-t3010798
Worked flawlessly when I flashed SlimLP a few weeks back.
A little offtopic, because in my country is 11:20 PM (23:20) a few erotic words :D :
Probably this is my first device, with so many roms. Best community ;)
In few minutes i try new twrp and flash again cm12.1
Man, I was really looking forward to cm12.1. Guess I gotta go back to my old cm 20150219 or flash a KK ROM
I'd rather flash KK...
@vm03
Bugs:
1.Setup wizard is buggy, force closes after asking for credit card....
2.Blank signal icon (d320n)
Why is SeLinux status Enforcing? Is it ok that way? Or it should be Enabled?
For ms323 setup is buggy ..I had to go to accounts and sign in with my Google......play store repeatedly crashes when installing apps...which isn't a problem with cm12.1 just gapps I'm guessing and the mobile data works but on status bar it show's no signal. That's all the bugs... Overall good ROM !!(:
WARNING: Force Close when Locking is still present in CM12.1 for ms323
Use a lockscreen app like ACDisplay
No force close here
I dont have FC for 8 hours i think.
New twrp is working great.
Signal is now fixed, flashed new twrp and reflashed cm12.1
I am using CWM. Cyanogenmod is working great but home and menu buttons are not working. Home button doesn't work at all and menu button works like back button. I am on LG L70 D320n. If I flash TWRP should it fix it ? And also isn't visible NFC icon.
Use TWRP. It's better than CWM.
I'm from Slovakia too.
Signal icon is normal, you can see it on last screen.
Orange Slovakia sim card is working like a charm.
But, when i try to lock screen, my screen turn on 100% brightness before screen is locked.
