Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
for me the signal icon is OK. but I have problem with buttons. is there way to fix it myself ? I really want to use it as my normal ROM but it has to be perfect.
Thanks for your efforts.
I can't encrypt my phone it always restarts when I press encrypt phone I'm using D325.
I get this in my logcat:
D/ ( 283): HW based disk encryption is enabled
D/ ( 283): Success loading QSEECom_create_key
E/ ( 283): Error undefined symbol: QSEECom_update_key_user_info loading symbols for QSEECom APIs
E/Cryptfs ( 283): Error enabling encryption after framework is shutdown, no data changed, restarting system
Mobile signal icon is working on Vodafone Romania. Installed newest TWRP->Fact. Reset->Clear Dalvik Cache/Cache/System->flashed CM12.1 & These gapps & lp-bloatware-removal-script -> skipped logging in google acc on setup, logged in afterwards.
I'm sorry, Facebook only for friends and my familly.
I dont know how, but is working when i boot with enabled data.
I think this is good function, why someone need internal disable script, when we have this?
I have sorted out how to fix setup wizard bug and blank signal....What i have done is flashed latest twrp with flashify, and after that boot to recovery, go to wipe, advanced wipe, and select everything, just leave sdcard empty, and do wipe,after that go to install, flash cm12.1, flash gapps, wipe cache/dalvik...after that go to home, again go to wipe, and do factory reset, and reboot to system.... :)
Edit: Still have blank signal icon bug after reboot.... :(
It's very annoying......when i turn on and turn off airplane mode signal icon disappear completely, and it won't appear unless i reboot phone, but after reboot only shows blank icon... :mad:
But still thanks @vm03 for your hard work ! You are awesome :)
Easyest way to flash twrp imo(you need root) is to go in the terminal emulator and type:
Code:
su
dd if=/PATH_TO_TWRP/twrp.img of=/dev/block/platform/msm_sdcc.1/by-name/recovery
in my case the path was /storage/sdcard1/twrp.img
I have installed twrp and now is everything working great :) no problems on D320n. You just have to use TWRP :)
Same Here
Still i got to ask VM03 or zlaja or any other DEV about :
1. a good camera aplication that allow us to save to sd
2. for the next update if its possible , vibrate on back button
3. any tweak or mod that you guys use on your phone
Feel free to share anything with us :P
Same Here
Feel free to share anything with us :p
I always liked Snap Camera, you can get a trial on GPlay, and then decide if you would like to buy it, it's cheap and has a nice interface with a lot of options. :) As for mods, this patch removes all CyanogenMod bloatware, I always flash it.
I also use Viper4Android as an audio mod/eq, it outclasses the CM one imho, and also works on bluetooth audio, which I mainly use. It has a lot of headphone modes and sound options, it's also free :).
Cyanogenmod 12.1 for LG L70 D320 D320n D325
My port of CyanogenMod 12.1 for LG l70 D320 D320n D325. It is unofficial and unsupported by the CyanogenMod team.
View attachment 85068 View attachment 85069 View attachment 85070 View attachment 85071
View attachment 85072 View attachment 85073 View attachment 85074 View attachment 85075
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and CWM or TWRP recovery.
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Working:
  • Display
  • touchscreen and multituch
  • Hardware 3D rendring
  • RIL - SMS, MMS, calls...
  • Mobile data
  • WiFi
  • GPS
  • Bluetooth
  • WiFi, Bluetooth, USB tethering
  • Audio - speaker, headphone, mic, routing, voip calls, etc
  • Camera - photo and video
  • SD card
  • FM radio
  • Hardware video decoding and encoding
  • Sensors
  • Double tap to wake
  • SmartCover
  • NFC for D320n
Not working:
  • Rear camera for D325f8 and MS323
  • Any others for unknown for me versions and revisions.
Download
cm-12.1-20150403-UNOFFICIAL-w5.zip https://yadi.sk/d/ee6HEuplfiuf4
Gapps https://www.androidfilehost.com/?fid=95916177934546454 or http://fitsnugly.euroskank.com/?rom=banks&device=gapps
TWRP v2.8.6.0 twrp_w5_20150403.img
Source
Kernel https://github.com/vm03/android_kernel_lge_msm8610
Device https://github.com/vm03/android_device_lge_w5
https://github.com/vm03/android_device_lge_msm8610-common
Proprietary https://github.com/vm03/proprietary_vendor_lge_msm8610
  1. Copy zip's to SD
  2. Enter to recovery
  3. wipe data
  4. install zip from external_sd cm-12.<...>.zip
  5. install zip from external_sd gapps
  6. reboot
Donate
Can't run ussd codes plz help me also camera low quality my 4n is lg l70 d325 plz reply soon
And also have a problem with charging..when I'm put to charge my 4n without turning on my 4n its show black screen and freeze my 4n plz fix this
I have used it all day and I found 2 problems. They are not that big.
1. Blank signal icon
2. After time my phone automaticly got Icons on screen back to stock. So I had to put every icon back on capital screen.
After problem 2, I found lroblem with blank signal icon.
Icons disappear after each restart if you move them to SD card, which you most probably did.
Oh yeah :D I did it :D but I was confused because they didn't disappeared right after moving them :) and signal icon was working but after that it stopped working so I was thinking that it has to do something with disappeared icons.
Yes, they will disappear on reboot :(
I also have d320n, I'm on RR 5.1 rom now (heavily based on cm12.1), for me signal glyph isn't blank :/
