Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Is this just for me or?, NFC isn't shown
SS down
Yes, they will disappear on reboot :(
I also have d320n, I'm on RR 5.1 rom now (heavily based on cm12.1), for me signal glyph isn't blank :/
For me it isn't that important. If phone calls, sms/mms or mobile data work good I don't really care :D Now I have goid phone with good ROM so I am happy :). I was wayting for this moment for years. I allways had bad phone and I always tested to reinstall it. When I had Iphone 3G I was using android on it but it was toooo laggy. Then I got ZTE Kis (the wors phone ever) and finally I have this :3. And I finnaly can install cyanogenmod :D
Every thing was going ok untill i restarted the phone i got the signal problem too after i did a restart
My phone always restart everytime trying to execute ussd code (like *111# etc).
Is it only me or that was general bug?
Edit: This happen if I chose "ask everytime" for calls. works fine if I chose default preferred sim for calls
me too.
and the select sim key not working
L70 D-325 dual
1 more question , how to put it .... grrrr here goes : dose the charging stop after 100% ? I think not and that i think will break the battery so vm03 can u do something about it ? Cose i put my phone to charge over the night and ... U know what i mean
I almost always charge phone at night. He is still alive. Charge control provides controller inside the battery, which does not depend on phone software. But custom roms it absolutly now waranty!
Please someone, I need help. I want to boot into Recovery but I don't want to lose Download mode which I lose when I unlock bootloader. Also I don't want to use any app to boot recovery. I want way that can be done when phone is booting so I don't need custom rom. How can I do it ?
Ok so my battery is gone ? Cose i feel like something is draining to fast and i said maybe it is a software problem becose i had my phone true usb on my laptop and it was 100% i did stress it a bit without taking out the usb and it was on 99% and in a min it was back to 100%
P.s im a newbie so pls dont shoot :)
Hello, """" cat /proc/cmdline | awk '{print $16}'| awk -F= '{print $2}' """""
It appeared on the screen LG-D320 - My device is LG-D325f8​
Works well, only network error.
Waiting for a correction patch for LG-D320f8 installed on my machine dual sim LG-D325f8. If someone else can offer a suggestion or tutorial or opinion is welcome. Congratulations on the hard work of developers. To my device missing only work the SIM card.
It appeared on the screen LG-D320f8 - My device is LG-D325f8​
You need correct bootloader (aboot.bin), for correct detecting you device version! D325f8 is dualSim?
Okay, yes ,my verison is D325f8 dual Sim ,thank you very much friend. Can you tell me how to do this procedure ???
mee too,,, n i dont know how to fix it,,,:(
Hello! (my first post ever)
One month ago I installed CM 12 on my D320N, by making a clean install (format system, dalvik).
Since then, everything has been working PERFECTLY.
One question:
What happens if I flash this CM 12.1 over CM 12 without wiping data? I have a lot of important stuff on the phone at the moment and I would like to keep it there.
Thanks!
