Simple answer:I can Flash de new update 20-5-15 if i apply Disable internal memory.zip ????
No. It will bootloop it.
Just download zip and reflash itCan someone pm me the cm cLock apk (not Clock
I cant. It will mess up link2sdJust download zip and reflash it
Than download the zip and extract itI cant. It will mess up link2sd
How do i extract an apk fron tge zip -_-Than download the zip and extract it
Yes you can, tested by me, and you will lose that "disable internal" thingI can Flash de new update 20-5-15 if i apply Disable internal memory.zip ????
Any apk from any build will work, I think. As long as it's 5.1 lollipopHow do i extract an apk fron tge zip -_-
I dont even know how to get itYes you can, tested by me, and you will lose that "disable internal" thing
Here's what todo:I dont even know how to get it
OK guys I'm running 5.1.1 with the latest ROM and its great but sorry if I'm bring back something that u guys awnsr all ready but when I try to go to settings it crashes and so does the ui do uvguys know and version that is working
Flash gapps! and wipe dalvik cache!You have ms323, right? Basically, that FCing was patched already. However, if it still happens to you, you can look at a thread that says UAYOR obsolete. I believe @LitrosNub posted it.
I run my me!
The only problem is that my phone is a bit quick download!I doHas anyone managed to get Xposed to work on the latest version of this ROM, it bootloops on me for some reason, even though it works fine on NamelessROM 5.1.1.
Nope, still bootloops, I waited for around 15-20 minutes and I am still on the bootanimation screen.Here's how to enable xposed on this rom:
http://wp.me/p5v2pH-4W
On clean install rom?Nope, still bootloops, I waited for around 15-20 minutes and I am still on the bootanimation screen.
Yes that is known bugmy usb mtp doesn´t work on windows.
any help?
Yes, I wipe all partitions except for storage ones, then I flash the ROM GApps and Facelock, at this point it boots fine and I go through the Setup Wizard after which I try to flash latest Xposed zip file which results in a bootloop.On clean install rom?
Try holding volume down + power while booting and let go of the power button for 1-2 seconds when the lg screen appears then press and hold power button again (never let go of volume down) until a factory reset screen appears, then go to yes 2 times and your device should boot into recovery.Hey guys i wanted ask if it iz possible to reboot into recovery mode through buttons?![]()
