VillaRuizHN
Member
:/ thanks!
I had class 10 but man it's also slow, there is no comparison sandisk ultra class II was i think was as fast as internal storage.Have $15 to spare? Buy a 32GB Class 10 SDCard:
http://www.amazon.com/Samsung-Class-Adapter-MB-MP32DA-AM/dp/B00IVPU786
That one is pretty fast, I got like 40 read and 30 write. Worth buying.I had class 10 but man it's also slow, there is no comparison sandisk ultra class II was i think was as fast as internal storage.
I'll buy another one.
That's weired because i had write/read of about 15MB with that ultra but it was like double or more faster than class 10 in opening apps and i didnt test for read/write speed. Probably is random read/write x5 from thise class 10 just like ssd vs hdd.That one is pretty fast, I got like 40 read and 30 write. Worth buying.
I din't know if update fried my sd but when something work great dont change it im going with sandisk again.Have $15 to spare? Buy a 32GB Class 10 SDCard:
Upgraded ram from 1GB to 2GBWhats is new in ver 20150524
You forgot to mention:Upgraded ram from 1GB to 2GB
Upgraded internal memory to 8GB
Added HW buttons bellow rear camera
Enabled camera laser sensor
- 1080p video recording
- Notification LED
- Display resolution updated from 480x800 to 1920x1080
- Updated camera to 13mpix
Wait with this update the ms323 would have 1080p display and 13mpix camera ??You forgot to mention:
Just sayin'.
Of course not. These are hardware features mainly lolWait with this update the ms323 would have 1080p display and 13mpix camera ??
Im not some tech geniusOf course not. These are hardware features mainly lol
OTA updates = pick up your device and put it on window and wait 30 min.How do you update the rom without deleting everything ?
Well that should put a stop to those who keep asking 'What's new?' in every update.Upgraded ram from 1GB to 2GB
Is not deleted. Sometimes you need up to 10 minutes for loading all apps from SD card.When you go to the sd applications and dex files to the application partition is deleted when you restart the phone
ThanksUpgraded ram from 1GB to 2GB
I'm using this rom (and cm11) on my D325 for more than 4 month. If you have an Issue just write on this forum, that is why we are here....i cant make this work on a d325. i have an issue with the sim. on kitkat "sim toolkit 2" worked fine. but now i dont have any network. dont recomend using this on a lg l70 d325.
mmm Could you explain what the upgrade to 8GBUpgraded ram from 1GB to 2GB
*facepalm *mmm Could you explain what the upgrade to 8GB![]()
welp, thats my issue.I'm using this rom (and cm11) on my D325 for more than 4 month. If you have an Issue just write on this forum, that is why we are here....
Isnt that what he just did lol ??I'm using this rom (and cm11) on my D325 for more than 4 month. If you have an Issue just write on this forum, that is why we are here....
lmfao he's ****ing with you, I felt for it toommm Could you explain what the upgrade to 8GB![]()
