Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
First of all thank you very much for this ROM..works great for me :). But after installing the last update ,when I install xposed latest farmware It stuck on boot:(. I have tryed this 4 Times but every time it causes bootloops...... So I decided to go back to the previous version of cm 12.1 but u have removed all previous versions:(....... What can I do? I need xposed.... please help............ Thank you
Xposed works fine for me with latest build (24/05/15)
welp, thats my issue.
this is:
this is everything i can tell about the phone, and about what i've done trying to fix it (downgrade, upgrade, change laf partition to the original etc):
only works the "back" button. home, options and the dual sim switcher doesnt.
y installed cm-12-something (tried 01-2015 and 04-2015). non of them recognized any sim. most of the times the message at the notification screen is "no sim detected", sometimes it shows the 0% network signal (as an empty triangle, it depends if i put the sim on the sim1 slot, or the sim2 slot, sim2 shows no sim, sim1 shows triangle).
now i think i dont have any root access because of the diferent roms i tried.
when i look at the phone software cm 12 2015 04 18 installed, the 05 24 isnt installed, should i install it?
other things:
the message i get when i try to fing network at the "aviable networks" on the about phone - status is:
network unknown, signal 0, mobile network unknown, out of service no roaming no nothing. (im using 2 diferent sims from the same phone company Movistar Argentina). the phone finds 2 out of 3 (Personal Argentina, but it doesnt find Claro Argentina). when i select movistar the phone is "registering on movistar" , and it fails at it. same with Personal. "your sim card doesnt allow conection to this network" (i can use the sim on any other non-android device).
one thing i see is the model, its d320 instead of d325. no vpn configuration (dont know how to change it).
i tried to restore de laf partition, but i failed, i think the problem is i lost the root. so the lg pc suit doesnt recognize my device.
this message is too long atm, so if u need something to know i ll let u know, thanks for the info u could bring me, and sorry for my poor english.
im open to any advice.
edit: i got the root acces again. also phone brings 0 contacts from sim.
when i try
Settings>> Security>> Set up SIM/RUIM Card Lock.
option is not available. (so i suppose is not sim card for the sim tool kit. i tried to overwrite this too, but failed. and didnt find the original sim toolkit 2)
1- use twrp to flash the rom
2- your aboot.bin is not for your phone, search the forum for D325 aboot.bin and push it to your device
3- sim change button doesn't work in CM. you can change your sim defaults in setting>simcard..
4- root access option is in settings>developer....
that it. just flash aboot.bin then twrp and then any CM version you want.
3 & 4 is done ! thank you man!
im new at this, so excuse me if i dont get any of it.
the aboot.bin is the reason why the device model is d320 instead of d325 ?
for 1 & 2:
i have many *.img from the backup made when i did the root->cm.12 installation. can i use that aboot.img?
the files are in folder "LG BOOT Backup": aboot.img, abootb.img, boot.img, laf.img, and recovery.img.
Problem solved .. I have put the aboot file (original) in the SD card and applied: dd if = / storage / external_sd / aboot.bin of = / dev / block / mmcblk0p6 bs = 4096
and the phone is now well recognized.
Only .. I have a new problem to get in RECOVERY mode : SECURE BOOTING ERROR
Thank you for helping me
i just found this in the previous posts. i believe doing it with twrp is easier than this.
pd. when i thy this at the command line
adb shell
su
dd if=/sdcard/aboot.bin of=/dev/block/platform/msm_sdcc.1/by-name/aboot
i get "permission denied". ( thread : http://androidforums.com/threads/dump-all-variants-aboot-files-and-how-to-flash.918174/ )
How can I fix this? It says storage space running out, but clearly I still have a lot of free space. I think this usually happens when clearing cache after restoring a backup. It's kinda annoying because the phone lags.
Gonna have to reflash fresh. same thing happened to me.
I just have a question. What exactly did you flash in recovery before you flashed xposed?
Also, did your phone boot before flashing xposed?
Someone have an D320 with rear camera working? because I install TWR and last release and rear camera and home button doesn't work. And for some reason that I dont know battery drains in 7 hours, and that is when I dont use it.
I am on lg l70 d325.........
I have only flashed the unofficial xposed-sdk22-arm-20150514......... After
flashing this my phone doesn't boot ......... If it is not the latest version please give me a link of the latest xposed firmware....... I have googled for the latast xposed it seems like this is the latest ........... Thank you
I had the same problem, bootloops on D320n after flashing latest xposed on latest CM12.1 this is how I (somehow) fixed it:
I wiped my sdcard(external) and redownloaded latest CM12.1, gapps and xposed and reflashed everything.
Also make sure that you don't flash anything other than ROM and GApps(no tweaks or modifications) before flashing Xposed, this fixed it for me.
When i turn off my l70(d320n) and plug in the loadingcable it loads but the screen doesn't turn off. There is still the backgroundlight turned on. Any help?
After flashing the latest ROM, I have only 2% free of system. What can I delete to free up some space? I know someone asked something similar in the past but I didn't understand well.
Also, since root is incorporated, do I need to install terminal and busybox?
1. Space is decreased for repartitioning space to have 2.5GB.
2. If you have installed BusyBox on another ROM installing it now is not required, just grab a terminal app from the Play Store.
So I fixed all my issues by switching from clock work to TWRP. The only issue I am having now is that when trying to update it says it has failed but the update menu says I have it installed??? The other issue is that when I have headphones pluged in the internal mic doesnt activate when i am on a call.
for 1 & 2:
adb shell
su
Hi,
@vm03 today i try to connect my device to sdk monitor tool with enabled nfc and here is error log:
Code:
05-27 14:27:43.527: E/NfcAdaptation(11383): NfcAdaptation::Initialize: ver=NFCDROID-AOSP_L_00.01 nfa=NFA_PI_1.03.66+
05-27 14:27:43.853: E/NxpHal(11383): i2c_fragmentation_status existing
05-27 14:27:43.854: E/NxpFwDnld(11383): Freeing Mem for Dnld Context..
05-27 14:27:46.089: E/NxpTml(11383): _i2c_write() errno : 5
05-27 14:27:46.089: E/NxpTml(11383): PN547 - Error in I2C Write.....
05-27 14:27:46.089: E/NxpHal(11383): write error status = 0x1ff
05-27 14:27:46.091: E/NxpHal(11383): write_unlocked failed - PN547 Maybe in Standby Mode - Retry
05-27 14:27:46.222: E/NxpTml(11383): _i2c_read() [hdr] errno : 6b
05-27 14:27:46.222: E/NxpTml(11383): PN547 - Error in I2C Read.....
05-27 14:27:46.223: E/NxpTml(11383): _i2c_read() [hdr] errno : 6b
05-27 14:27:46.223: E/NxpTml(11383): PN547 - Error in I2C Read.....
05-27 14:27:46.224: E/NxpTml(11383): _i2c_read() [hdr] errno : 6b
05-27 14:27:46.224: E/NxpTml(11383): PN547 - Error in I2C Read.....
05-27 14:27:46.225: E/NxpTml(11383): _i2c_read() [hdr] errno : 6b
05-27 14:27:46.225: E/NxpTml(11383): PN547 - Error in I2C Read.....
05-27 14:27:46.226: E/NxpTml(11383): _i2c_read() [hdr] errno : 6b
05-27 14:27:46.226: E/NxpTml(11383): PN547 - Error in I2C Read.....
05-27 14:27:46.230: E/NxpHal(11383): CORE_RESET_NTF received!
05-27 14:27:46.230: E/NxpHal(11383): phNxpNciHal_emergency_recovery: abort()
05-27 14:27:46.231: E/BrcmNfcNfa(11383): reset notification!!:0xa0
05-27 14:27:46.231: E/BrcmNfcNfa(11383): NCI version mismatch!!:0x10 != 0x00
05-27 14:27:46.231: E/BrcmNfcNfa(11383): NFCC version is too old
05-27 14:27:46.231: E/BrcmNfcNfa(11383): Failed to reset NFCC
only errors log from com.android.nfc app
And full log :D
By the way, i google some errors and i find one user from One plus One here:
http://forum.xda-developers.com/showpost.php?p=60298321&postcount=303
He replace .so file this make errors like in my full log:
05-27 14:43:14.424: W/linker(13653): libpn547_fw.so has text relocations. This is wasting memory and prevents security hardening. Please fix.
