Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
I know about the news. :) Seen it around. Just wondering how it's done
Whoever did it, first I'm gonna kiss him in the arse, and then ask this
Hello community, I am using the latest version of cm12 527, and I have a problem with the flashlight, whenever I try to turn it on it dosent want to. And also I have some problems with my gapps I downloaded play games, and it didn't allow me to sign in please direct me to the right gapps to use. Thanks in advance
Hello all,
I can not set the camera to save to the external sd card, I do not have that option in the camera settings; I have tried to create a symlink with the external sd card folder, but the camera said that I should insert a sd card.
On Google (cyanogenmod.org forum) I fiind that this option it is not available, am I wrong?
Thank you !
This option is not available in default camera apk.
Try Snap Camera, this is better option and in Snap Camera enable Camera 2 Api for better results!
I will try them, and see which one it is good for me.
I have tried focal (it is in beta), I like the interface, but needs more work.
Thank you !
Does anybody know how to change the shortcut button on the MS323 (the button right above the volume button) to a different shortcut on this rom ???
You can use xposed addition
Or..
Manually edit 2 files:
System/usr/keylayout/gpio-keys.kl
System/usr/keylayout/generic(your phone model).kl
Can I flash this rom on my Lg realm (ls 620)? It is nearly identical to the l70, just a different carrier, in fact the back of the phone says l70 all over it. I do not use the cellular portion, so that doesn't matter. Everyone's opinion is greatly appreciated. The recently was a recovery released for the realm, which I installed, so now it is easy to flash new things to the phone. Once again, thank you.
No, it will flash fine but will have touchscreen issues on startup.
