trippymyke XD
How do you disable internal memory. I can't find the option, and I read a couple pages back and on thing on it.
You cant.How do you disable internal memory. I can't find the option, and I read a couple pages back and on thing on it.
I thought that I read someone saying in the new update that you could. Thanks for the fast replyYou cant.
Well there might be a way in the future to use the SD card instead.I thought that I read someone saying in the new update that you could. Thanks for the fast reply
Here you goI thought that I read someone saying in the new update that you could. Thanks for the fast reply
Thats lg rom specific. Cm12 doesn't have it from what i rememberIt's a way to enable quick window function for this rom?
Facebook is a certain app?Anyone else experiencing that certain apps like Facebook, freezes while scrolling?
I don't have this problem. Maybe is only Facebook problem (Facebook - thousands of developers but app is optimized like first beta of GTA V)
Facebook is generally a crappy app. I personally browse Facebook via web browser, and for chat I installed Facebook Messenger which is an excellent app, as opposed to Facebook app. Maybe because it's developed by whole another dev teamThanks for quick reply
Facebook is full of bugs, so you're probably right. I did try different fb versions all the way back to 27 but same issue, so I thought maybe it's a lollipop bug?
Facebook is generally a crappy app. I personally browse Facebook via web browser, and for chat I installed Facebook Messenger which is an excellent app, as opposed to Facebook app. Maybe because it's developed by whole another dev team![]()
Quick Windows case does not work on the cm-12.1.Just turn off and on the phone.I saw this picture on CM12 320 thread on page 23,it' s that posible for CM12.1. I put a magnet, I have case with smart window, but nothig is happent....http://androidforums.com/threads/unofficial-cyanogenmod-12-for-lg-l70-d320-d320n-d325.893621/page-23
Try NamelessROM, it has some options for the lid under display settings, but I don't have smart cover to test that. Please test and report if you can.Thx for the film. I understand.
Guess I was wrong.Here you go
https://cloud.mail.ru/public/2rqqJjRz4EDb/Patch/Cm12.1/Disable_internal_CM12.1_27.05.15.zip
Credit @vladimirs77
*edit
This is for build 27 May, sorry, forgotten.
Thanks, about to try nowHere you go
Credit @vladimirs77
*edit
