Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Hey, I got the D320n and there are some details and some problems I noticed:
1. When I turn off wifi there's an exclamation mark next to the telecom symbol (only visual error the mobile connection does still work)
2. When I plug in headphones the audio symbol doesn't change.
3. The flashlight doesn't work.
4. Unfortunatly I'll have to answer the question "Does NFC work on D320n?" with a no.
5. It would be helpfull that you could turn off vibration.
But overall a awesome ROM! :)
I have the exclamation mark to. Not a big deal. Cant test headphones cus some jackass sent 40volts down my headphone jack and fred it. Flashlight works when the phone is restarted (i had this issue). And i shall test nfc at school with a samsung s5.
I tried to flash through CWM. The home button and internet didnt work. I got a signal bar with a "!" in it. I flashed twrp and then reflashed rom. (After scanning through thread, so many pages.) Home button started working, but signal stayed same. I went to mobile networks and seen that i needed to set metro apn, also while i was in there i seen that it only has 3g and 2g options. Neither way let me flash Gapps, i got insufficient storage error. Any help to get me through this would be appreciated. I did see somewhere in OP something about ril keys and something about aboot. If anyone cares to explain both that would also be appreciated. One other thing. I enabled development options and it has a place that root access disaled. I enabled it for apps and adb. Is that correct?
Edit: I am using M323 firmware C
how in the world are you even doing anything
you need to be on firmware B to even be rooted
Must you do everything? I don't appreciate the sarcasm thanks. I assumed that if its not available in my country then if i use VPN, whats the point, since it wouldn't work in my country anyway
okay then leave you phone as is there is no need of it, alternative just get an apk
Might as well wait for android M and android pay if this isn't available for me. Do you use Google wallet? Do you find it good?
both not out yet m is do Q3 of 2015 and idk for pay, and why do you want them is it for the wireless pay cause i honestly think that is jsut a risky move to have things like that opens more gates for hackers
Hi,
NFC is not working. There're problem with files i think.
You mean the navigation bar that is on the bottom? If so, you will have to add to /system/build.prop the line qemu.hw.mainkeys=0, and reboot.
[QUOTE = "post ltmpx: 6988591, üyesi: 1847043"] Sen altta gezinti çubuğu demek? Eğer öyleyse, çizgi qemu.hw.mainkeys = 0, ve yeniden /system/build.prop eklemek gerekir. [/ QUOTE]
not be tried
