Please do your best to use a translation service like google translate. Posting in even broken English will greatly increase your chances of getting help.Navigation bar rom dahili ?
I think it is getting confused on dahili. I think it means internal, but I am unable to put that into context with the rest of the post.Rebooting didn't fix the flashlight in my caseI have the exclamation mark to. Not a big deal. Cant test headphones cus some jackass sent 40volts down my headphone jack and fred it. Flashlight works when the phone is restarted (i had this issue). And i shall test nfc at school with a samsung s5.
Hi, I did not find your phone type in your signature, but according wit the dev @vm03, "w5 for L70, w3ds for L40"When i try to install from SDCard it fails saying that This Pack is only for w5 and w5ds this device is w5 ? how can i fix this ?
and when i try to install the gaaps says invalid failture ?
Any sugestions ?
Understand, mine is the d325f8, I'm from Brazil, tell me what will I need to do in order to make the camera work? you could get ums files and try to make the rom his stock? I will use test.D325 or D325f8? On my D325 camera works. If it D325f8 or another unknow revision of l70 I need device in my hands for try to fix camera.
Use g translateHer ne kadar ağ modu hızlı ayar
I dont get you???[QUOTE = "post Tweakforce_LG: 6988967, üyesi: 1815740"] tercüme g kullanın [/ QUOTE]
I change the speed settings in the network mode, we could
Vm03 needs a f8 version sent to him to develop a camera fix for cm12.1It is the way the d325f there will be no back camera
No, I was on c with locked bootloader and used king root then used flashify for twrphow in the world are you even doing anything
you need to be on firmware B to even be rooted
I write this few days ago. I post log too, but there're not a chance to fix a think.Ok i tested nfc today with an s5 and a d320n. I can confirm it is not working. Im on version 0508 though. What steps are nessasery to develop a fix for this? Im willing to help
Not poromisimg, if i get time i will. Im still on update 0508. A month out of date but its stable and link2sd stops me updating. No real benifits to updating for nowI write this few days ago. I post log too, but there're not a chance to fix a think.
It seems one of file is invalid or broken. I think VM03 must need d320n in his hand to fix this.
http://androidforums.com/threads/un...-d320n-d325-ms323.912225/page-42#post-6980914
Maybe is there a chance. Download original lollipop rom for L90 and find .so file in this rom.
I think it need kernel changes. But it need some research with device.Understand, mine is the d325f8, I'm from Brazil, tell me what will I need to do in order to make the camera work? you could get ums files and try to make the rom his stock? I will use test.
As I think, kernel part of nfc works, problem in android hal.I will try it today.
@vm03 http://opensource.lge.com/fileMgr/download/op/D405N/506343?
Source code for L90 with nfc, maybe this can help?
Can someone please help me figure it out with the CyanogenMod 12.1 for L70 D320n
I rooted the phone, i cant unlock the bootloader it just don't work that, can someone show me how to install TWRP and how to install the whole Cyanogen Mod 12.1 ? Thank you...
