Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
The only problem i found. or maybe I did something wrong...
But I lost the Root on my MS323c after install this ROM.
This is a Really Nice ROM.
Thanks ;)
Thanks ;)
No, you did not lost root on this ROM, you just have to enable it from developer option>root access, and choose one option from there
Hello,
I have 2 files under /data/local, with some tweaks to be done to build.prop and sysctl, named user_build and user_sysctl, with permissions of 751, but the instructions from those filesare not executed. Both files have in the begining:
#!/system/bin/sh
mount -o rw,remount /system
so it should be ok, but ....
I also tried to execute them from /system/etc/init.d/ but with no success.
Can someone give a hint?
Edit: it looks like the script stucks at the mount -o rw,remount /system part, because when I do the command manually, the rest of the script runs without problems...
Can you help a noob ? Thank you!
Edit: I have tried to use local.prop, in /data/local, in order to overwrite the /system/build.prop, I run the script placed in /data/local/userinit.sh and it runs OK, I place it in /system/etc/init.d and run it, and it runs, but it never runs at boot, not from any location. It is something wrong with cm, or I am the wrong :) one?
Later edit: I have tried all the possible combination, but it seems that the scripts inside the /system/etc/init.d are not executed; maybe in the ramdisk the userinit it is disabled?
If someoane can help a noob ....
Thank you!
Easy fix. Just go into system/usr/keylayout and delete Generic.kl, then rename GenericMS323.kl to just Generic.kl and you should have your keys working again!
I just finish to install cwm, cm12.1 latest, and did what you said, and IT IS PERFECT!, not that I did not belived you, I was just curios!; my only regret - I whish I knew this before I brick my phone.
Now I will flash twrp back :)
No worries. :) just glad that it worked
