Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Alright.. I'm sure someone has asked but there's a lot of pages to search lol, but I have signal I can call and text no problem but I have no mobile data, all it is is the signal and an exclamation point, any idea how to fix? I'm on the latest cm12.1 lg ms323
go to setting/mobile networks/ access point names and create a new APN.
APN setting could be found in your SIM providers website.
save changes and enable data.
if had any problem try a restart.
Thanks for your work, but my phone is stuck on bootloop.
Just a question. Is it possible to enter in recovery mode via hardware button? :)
As far as I know, you can try to get into hard reset - power off the device, press volume down and power, and when the logo appears release the power button while keeping the down volume pressed, and after 1-2 seconds, press again power and keep them till you will get the factory reset; select with volume key "yes", and then the recovery mode will appear :)
Best regards!
Thank.. But it doesnt work.
I manage one time to enter in recovery.. But i don't know how. The USB cable was in..
It was the download mode, and I guess that you activate it by volume up and power; if you have a custom recovery flashed, such as twrp or cwm, by going in the hard reset mode you can enter recovery mode. From download mode you can use the lg flash tool to flash back the original rom
I think you already know, but the nfc is not working on the D320N.
Is there something that i can do to help you to fix this problem? Do you needs logs or something like that.
I really need the nfc for updating the public transport cards here in Holland.
No, i already sent logs to vm03. Error is probably in Android HAL. vm03 must have device in his hands, to fix this error.
If you want working NFC, flash stock rom.
I read in some of the 56 previous pages that it was probably a problem in the hal layer.
However you can debug now with adb over tcp/ip so if someone (me) connect his phone to the net vm03 can debug remotely.
Else if there are enough participants that want's ncf we can collect some money to buy togheter a D320n for him to solve this problem.
Phone is €120 here in The Netherlands, so 20+ participants will be enough to make it interesting for everybody.
Edit:
Quick search looks that i'm missing (at least):
/system/etc/permissions/android.hardware.nfc.xml
/system/etc/permissions/android.hardware.nfc.hce.xml
/system/lib/hw/nfc_nci.w5.so
/system/app/NfcNci
Edit:
/system/app/NfcNci
People barely managed here to collect 20$ for a 30$ broken ms323 (thanks @shellboy32). Even vm had to chip-in himself for transport. Good luck with this cimmunity here :D I don't mean to be rude, but really, tough luck on that.
So true, it's mostly because people here don't trust people with there money (honestly when shellboy didn't get online much I thought he wasn't gonna come back and scammed us) if someone wants to donate something it needs to be from a trustworthy person, ect.
/system/app/NfcNci
I have all files in nameless rom. I try fix NFC several times (20 working hours) nothing easy, very hard for me. But everything is here (something is not working)... Nobody who knows.... It's a big mystery! We need Scooby-Doo team asap.
I, unfortunately, cannot test NFC as I don't own tags, nor there is someone with NFC device around me. All I can test is toggling, which, of course works... :/
zlaja, on aliexpress or ebay are nfc tags only for $0,55 with free shipping maybe i can order you one
Edit: why is first shop on censored list? Is normal legit shop. I have more than 100+ orders from this website everytime 100% sucessfull and best quality.
Hei guys, i just installed cm12.1 on lg d320n works like a charm but only thing that anoys me is the list menu. Is there a way to chage it to icon instead of list :-s ?
Try Homescreen Settings, Drawer Settings, Layout to Paged and the rest is quite self explanatory like sorting mode, etc.
Is anyone else having trouble with photos?
Can't take screenshots (error occured due to limited storage or the app doesn't allow it) and in the gallery app, only certain photos show up in gallery, it's weird. New photos, be it from the camera or images from the Internet don't show up in gallery either.
Im on an MS323 by the way.
I don't have homescreen settings, i guess should be under device where locked screen settings are. I also tryed long tap on desktop an the settings but that pops all the settings.
thx
Press on the advanced meniu, it will show Wallpapers, Widgets and Settings; above this you have 3 dots shapping as an up Arrow, press them and voila, Home Screen Settings
thx
I attach some screenshots....
[QUOTE = "VM03, pós: 6.931.394, membro: 1.778.641"] Cyanogenmod 12,1 para LG L70 D320 D325 D320n MS323
Meu porto de CyanogenMod 12,1 para LG l70 D320 D320n D325. Ele não é oficial e não suportado pela equipe CyanogenMod.
