I deleted old files...
I don't have it problem on all of my 3 devices. May be @zlaja84 can find where problem? He have this problem, and have skills.The slow charging issue is become a serious problem for several users.
Please do something with it @vm03
At least give a release without LGE battery patch as an alternative.
I agree, would rather have to wait for charge than burn the house down lolI don't have it problem on all of my 3 devices. May be @zlaja84 can find where problem? He have this problem, and have skills.
I don't like to revert this code, it add safety for battery and fix some another problem.
You overestimated meI don't have it problem on all of my 3 devices. May be @zlaja84 can find where problem? He have this problem, and have skills.
http://androidforums.com/goto/post?id=7144512#post-7144512Somebody can help me to solve my problem with SuperSU please?![]()
He solved the problem activating root access in Developer Options, but i have it activated already
Flash in TWRPHe solved the problem activating root access in Developer Options, but i have it activated already
root still fails. please helpHe solved the problem activating root access in Developer Options, but i have it activated already
Mine works fine [emoji14]You overestimated meI don't know how I woud debug such a problem, to be honest. But I do believe that somewhere deep in the patch, our battery is being declared as 1700 mAh instead of 2100, and that's why it stops at ~80% of charging (and then you must replug the device to continue charging). But this here says says I'm wrong...
Just to be clear, I don't like the fact that I reverted that patch on my ROMs, as that broke offline charging, but I had no choice...
That's the problem, for some users it works just fine, for some (me included), not.Mine works fine [emoji14]
Flash in TWRP
Change is hardcoded in the kernel, which means that I would have to build kernel twice for each release I make, twice making zip packages, etc. Count the amount of ROMs I support and do the math. Honestly, I'm way to lazy for thatcan you make a zip file to revert LG battery code ? or ?
Try bluetooth headphone.Gotta say after my phone got half killed with a dodgy headphone jack meaning i cant use headphones on it, finding you awsome devs and the ROM really made my phone worth keeping again, no music sucks, but that combined with the laggy stock rom almost made trash it. Thanks a lot, please dont let the projects die too soon [emoji14]
