way to go..2015-11-28
- MTP fix by @vladimirs77
Need remove LG usb driver and install Google usb driver on Windows.
As I wrote, remove LG drivets!Newest update crashes my pc giving blue screen error upon connection (11-28) thought it was my PC but it wasn't after reflashing last weeks rom, USB works again.. I'm running windows 7 if that matters
Here are the latest build CM12.1 modified kernelway to go..
just one more issue to resolve, that notorious charging issue...
Allright, thanks @vladimirs77, gonna test it ASAPHere are the latest build CM12.1 modified kernel
http://sh.st/nyAfM
format your sdcard with pc and after that format it with TWRP recovery and re-install CM12.1.
can i install it using CWM ?Cyanogenmod 12.1 for LG L70 D320 D320n D325 MS323
My port of CyanogenMod 12.1 for LG l70 D320 D320n D325. It is unofficial and unsupported by the CyanogenMod team.
View attachment 85068 View attachment 85069 View attachment 85070 View attachment 85071
View attachment 85072 View attachment 85073 View attachment 85074 View attachment 85075
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and TWRP (20140403 or later) recovery.
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Working:
Not working:
- Display
- touchscreen and multituch
- Hardware 3D rendring
- RIL - SMS, MMS, calls...
- Mobile data
- WiFi
- GPS
- Bluetooth
- WiFi, Bluetooth, USB tethering
- Audio - speaker, headphone, mic, routing, voip calls, etc
- Camera - photo and video
- SD card
- FM radio
- Hardware video decoding and encoding
- Sensors
- Double tap to wake
- SmartCover
- NFC for D320n?
Download
- Rear camera for D325f8
- Any others for unknown for me versions and revisions.
See new builds on http://vasy.ru/CyanogenModOTA/builds/full/
(w5 for L70, w3ds for L40) or use OTA.
cm-12.1-20150416-UNOFFICIAL-w5.zip
cm-12.1-20150411-UNOFFICIAL-w5.zip
cm-12.1-20150403-UNOFFICIAL-w5.zip https://yadi.sk/d/ee6HEuplfiuf4
Gapps (i recommend nano) http://forum.xda-developers.com/android/software/reborn-gapps-5-t3074660
TWRP >= v2.8.6.0 http://androidforums.com/threads/twrp-ms323-d320n-d325-team-win-recovery-pro-2-8-6-0.911656
Source
Kernel https://github.com/vm03/android_kernel_lge_msm8610
Device https://github.com/vm03/android_device_lge_w5
https://github.com/vm03/android_device_lge_msm8610-common
Proprietary https://github.com/vm03/proprietary_vendor_lge_msm8610
- Copy zip's to SD
- Enter to recovery
- wipe data
- install zip from external_sd cm-12.<...>.zip
- install zip from external_sd gapps
- reboot
Donate
Is working dual chip from LG l70 d325f8 Dual ?Cyanogenmod 12.1 for LG L70 D320 D320n D325 MS323
Working:
Not working:
- Display
- Mobile data
- WiFi
- GPS
- Bluetooth
- SD card
- FM radio
- Sensors
- SmartCover
- NFC for D320n?
Download
Source
- Copy zip's to SD
- Enter to recovery
- wipe data
- reboot
Donate
su (press Enter)
setprop persist.sys.usb.config mass_storage,adb (press Enter)
So , battery patch is reverted?In previous builds trouble charging was not, and the new build no problems
Perhaps the problem with a USB cable , try a different cable.Something extremely bad happen to my phone (LG L70 D325).
Anyone knows this problem?
This image happen when I charge my phone.
This image happen when I disconnect from charging.
If anyone knows this problem, please help. Thanks!
