Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Anyone having issues regarding Data connection? My APN is configured correctly but somehow I can't connect to network. The confusing part is that when I'm on initial Setup Wizard, I can connect to. data but After some time I can't connect.
Flashed the ROM on my wife's d320n a couple of days ago. She loves it but her home button won't work and she's been a pain in the arse because of it. Is there a fix for that? Help a poor fellow out lads. Thanks
Any help? I cant partition my sdcard by TWRP :/
What smarmylamb said, or you can go with a Root Browser to system/usr/keylayout and change the generic.kl with the generic-d320.kl (just rename the first with a random name and the generic-d320.kl rename it to generic.kl)
It worked! Thank you, sir!
@Smarmylamb Thanks for the taking the time to answer.
Something weird is happening with the last update (12.1-20151121), the phone sometimes freezes for long times (1-2 minutes), sometimes after freezes it removes my wallpaper and put the default wallpaper.
The only thing I have done right now that I can consider can create those problems is the DataOnSD, but I'm not sure of it
my phone is d325.I can not big file transfer ( mtp and ums) after flash cm12.1 and any custom rom. No problem with the original ROM.only problem is going have installed custom ROMs
<translated by google>
Hello,
I've got a problem: I cannot connect to internet, both WiFi and mobile connection will fail to connect (built-in browser shows error ERR_TIMED_OUT). I know that mobile connection works as I can start HotSpot and connected devices can access internet through it. What can I do? (LG D320n)
OK, this happens only to preinstalled apps. My own app can reach internet without any problems and also searching for updates doesn't yield any errors (I thought it just ignores problems, but it looks like it doesn't have any). The question is still the same: how could I solve it?
EDIT: Firefox has the same problem (but Sync can login), F-Droid sometimes fails
Also I cannot connect to local IP addresses (in local network), it throws error ERR_PROXY_CONNECTION_FAILED; Firefox complains about timeout.
Anyone have idea of how to fix this problem?
@vm03 @lmntrix @Maslovicz @zlaja84 Battery is taking 10 hours to charge even after a proper clean install and calibration by charging it to full 100% and draining back till 0% and charging again. I observed that the LGE BATTERY PATCH has been implemented (err..REVERTED) in the Euphoria & AOSP builds. Should I flash any of those builds to get rid of this brain hammering problem once & for all or is there any miracle in your magic wand to help me solve this issue like many others on the latest cm-12.1-20151121-UNOFFICIAL-w5 build. URGENT HELP REQUIRED. Thanks. :(
@vm03 @lmntrix @Maslovicz @zlaja84 Battery is taking 10 hours to charge even after a proper clean install and calibration by charging it to full 100% and draining back till 0% and charging again. I observed that the LGE BATTERY PATCH has been implemented in the Euphoria & AOSP builds. Should I flash any of those builds to get rid of this brain hammering problem once & for all or is there any miracle in your magic wand to help me solve this issue like many others on the latest cm-12.1-20151121-UNOFFICIAL-w5 build. URGENT HELP REQUIRED. Thanks. :(
First of all, calibrating li-ion battery is a myth.
Second, all of my ROMs + Euphoria by Maslovicz have LGE battery patch REVERTED, because that patch is causing bad charging, at least for me.
@zlaja84 Yep, I used to believe the same until @lmntrix suggested the calibrating solution in the cm13 thread wherein I had reported the same problem earlier by mistake. But after following his solution of re calibrating the battery and finishing a full battery cycle, I didnt seem to get rid of this irritating issue. Thanks for the valuable suggestion. Lastly, I just found AOSP build for LG L70 under your name. Do tell me the other builds for this phone which you've made so that I can go through them before flashing the AOSP/ Euphoria rom. Cheers. Thanks again! :)
Thank you for this new version. Still does not work the SIM card. gapps not install, says it is incompatible with the ROM. Yet we have to acknowledge the efforts.
Sir,
Mine is L70 D325 Version, post installing this cyno mod, it now shows D320 in :about : , also the sim cards are not detected. Can you kindly tell me solution?
