What a build with lge battery patch reverted guys?
I try the last version and still slow charging issue dude..You don't have to search for a version that's without the patch. There's no problem with slow charging anymore. Download the latest version and try it.
I do I have proper charger, maybe i should change another charger..
But when i used euphoria os battery charging it's normal, maybe it's kernel problem dude? Can i flash boot.img from euphoria to cm12.1??
Latest Euphoria has tle lge battery patch reverted. Source : I built itBoot.img contains ramdisk and kernel so I see no point in swapping it, since Euphoria is actually built from Cm sources it would make no sense.
Try a different charger, maybe it will do the trick.
most of my LP roms have it reverted as I had the same problem as he is having.Latest Euphoria has tle lge battery patch reverted. Source : I built itmost of my LP roms have it reverted as I had the same problem as he is having.
Yeah, it's quite random, only some users are affected, including me, unfortunately. I tried switching chargers, but to availAnd now we have a 101% correct answer
Thanks, and sorry if I made any confusion.
Still, it's strange that I don't have such problem with this CM 12.1![]()
So @zlaja84 I must flash boot.img from latest euphoria right? I have D325 or what build you used for normal charging?Yeah, it's quite random, only some users are affected, including me, unfortunately. I tried switching chargers, but to avail![]()
No you can't, because boot.img from euphoria is different from cm's boot.img. The only solution for you is to build cm12.1 from sources, with lge battery patch reverted.So @zlaja84 I must flash boot.img from latest euphoria right? I have D325 or what build you used for normal charging?
Okay.. But I did flashed boot.img from latest euphoria, it's seems back to normal charging @zlaja84.. It's weird case you know..No you can't, because boot.img from euphoria is different from cm's boot.img. The only solution for you is to build cm12.1 from sources, with lge battery patch reverted.
Well, it MAY workOkay.. But I did flashed boot.img from latest euphoria, it's seems back to normal charging @zlaja84.. It's weird case you know..
I'm glad it works for you
but no guarantees, you know, other bugs may arise because of that.OkayWell, it MAY workI'm glad it works for you
I keep looking for bugs..Hi, can you share that boot.img? And also how did you replaced it, Just flashing? Theres still offline charging animation or it brokes? TnksOkayI keep looking for bugs..
Why my phone cannot update binary after installing cm 12.1?,
In supersu apps, please help meWhy my phone cannot update binary after installing cm 12.1?,
Can you give me files?,.pleaseSuperSu may also be updated or installed through a recovery. The package is on xda, but you may also use a search box to find it somewhere here. After flashing it from the recovery, you no longer need to update binaries.
BTW, you don't need the supersu at all since cm12 and up has its' own root manager.
So, why can not I using link2sd?,
Right, i will find that fileNow you are just being lazy.. Could you please use Google and type "SuperSU XDA" if you have no time to search the forum?
Link2SD works just fine, as some people reported. Don't know what problem are you having, but unfortunately I cannot help with it, cause I never used it![]()
I just flashed this ROM and it's having a big memory issue. I couldn't even install the micro gapps package. I had to use the pinco or what ever it's called with only the play store.
I have a 32gb class 10 SD card with a 1 and a half GB partition. IDK the brand off the top of my head but it's a pretty nice card. I've been using it in other phones for a while without issues. I wiped and repartitioned it just before flashing this ROM. I was using Apps2SD All In One Tool and after moving apps I'm still getting low memory pop-ups. I don't think it's a issue with the app cause I'm using it on a few other phones with our any problems. Also after a reboot apps on the partition are gone.
Is there something built-in to this ROM that is conflicting with the app?
Thanks for any help.
Hey can you help me, I really want to make my phone have 2.6gb internal.You know what I did a long time ago?
I re-partitioned my internal memory with Partition Table Tool from this thread . From then on, I have 2,6 GB of internal memory (independent of my SD card). So, I've never bothered with Apps2SD or Link2SD, or any other
BTW, this ROM is outdated, so if you really want an up-to-date CM12.1, download it from here .
