shhnedo
Member
http://androidforums.com/threads/di...oid-lollipop-and-partition-table-tool.921136/Where is the download from the latest version from W5? On vasy site is just 19.12.2015 the latest version available.
Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323Hello World! Help me please.
I have an LG L70 D320N
I tried to install Cm12.1 everything is ok, after installing the software tries to install drivers for connecting to the computer but PC restarts. Blue screen appears.
How do I fix. Thank you for the help!
Yes and no. With this rom you are capable to do it but you need to use repartition table tool to change the size of partitions to whatever you want then use a internal disabler wich bassicaly will erase your "emulated internal storage" and all apps now will install in external, you need also the last updated version of the rom, but dont worry is all in hereDoes anyone know if after installing this there is more or less internal storage free than the miserable 1.5gb that lg gives you? (D320N)
<br />http://androidforums.com/threads/di...oid-lollipop-and-partition-table-tool.921136/[/QUOTE]Yes and no. With this rom you are capable to do it but you need to use repartition table tool to change the size of partitions to whatever you want then use a internal disabler wich bassicaly will erase your "emulated internal storage" and all apps now will install in external, you need also the last updated version of the rom, but dont worry is all in here
Use TWRP is highly reccomended (by that i mean mandatory)When I tried to install this rom with CWM Recovery it gave this error message in the console:
This package is for device: jag3gds; this device is w5.
E: Error in /external_sd/ROMS/cm-12.1-20151224-UNOFFICIAL-jag3gds.zip
(Status 7)
Installation aborted.
And it put me back into the "Install update from zip file" menu... any ideas?
(Status 7)
And it put me back into the "Install update from zip file" menu... any ideas? (d320/d320N)
Well it works now, but there are a few weird things. I haven't installed gapps yet, but will do that next.^ jag3gds IS NOT the L70, it's the G3 S(completely different device). L70's codename is w5. Also, you really should be using TWRP instead of CWM.
I actually don't know... It's been a few days of nightmares to get here XD Would that fix my buttons problem?Because you didn't flash the aboot.bin(bootloader) for your device?
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Are you sure your device is the 320N variant?any ideas? (d320/d320N)
The N is because it has NFC right? If so yes it's the N variant (even though I never use NFC).Are you sure your device is the 320N variant?
About the BSOD issue - uninstall the LG driver and use the google one.
