Tweakforce_LG
Do you speak English?Hola esta ROM viene rooteada
i guess that is a NO... :/Hola esta ROM viene rooteada
My model is LG L70 (d320n). The same as you. Then everything goes right?For what model for l70. I'm on the d320n and camera works
Hola, para instalar esta ROM tienes que rootear el móvil. Yo use el vídeo que te dejo abajo y me sirvió.Hola esta ROM viene rooteada
ENGLISH PLEASE!Hola, para instalar esta ROM tienes que rootear el móvil. Yo use el vídeo que te dejo abajo y me sirvió.
Link:
Should do but I used cm12.1 not cm12My model is LG L70 (d320n). The same as you. Then everything goes right?
Link:
This is an English speaking forum. If you need any help translating, a service like Google Translate might be helpfull. Cheers.Hi Everyone! I'm new on this Forum
I Have Lg L70 D320 and i flashed Cm 12 2015-04-11 & TWRP 2.8.6.0
Everything seems to be OK but MMS not work.
A readed in internet that android 5.0.2 have problem with MMS.
I don't have a time for reading all posts, could anybody know how to repair MMS ?
Sorry for my english
Thank's for all reply
sim switching button is disabled. you can change the sim in settings>sim cardSir I'm having an LG L70 D325 Model Phone Dual Sim I have installed everything works fine i am having no problem, but a little problem which I'm facing in my phone when i need to do any call from my second sim the sim switcher button on the navigation bar is not working. Whenever I'm calling anybody the call is being made from the first sim. Please Help With an solution!
Like Mortz said the Sim switcher button is disabled , your best bet is to go to SIM card settings, and set it to prompt, and then decide which sim card to use before making a call. These settings you can also specify which sim card to use for data connection, sms, etcSir I'm having an LG L70 D325 Model Phone Dual Sim I have installed everything works fine i am having no problem, but a little problem which I'm facing in my phone when i need to do any call from my second sim the sim switcher button on the navigation bar is not working. Whenever I'm calling anybody the call is being made from the first sim. Please Help With an solution!
Hi! I'm also new here ... How is the performance of your camera? Some important bug apart from MMS? Thanks in advance
The country where I am at doesnt allow MMS so cant help you there, what I do is just install an app such as Whatsapp, imo, etc and send MMS from there
Lg l70 d325f8 sim card dont work please update!Changelog
2015-04-18
Changelog
2015-04-18
2015-04-11
- Last build, more only CM12.1
2015-04-04
- Fix manual network search and select
- HW composer props for 8610
2015-03-28
- Fix NFC
- Memory perfomance optimizations
- Fix CVE-2015-1465, CVE-2014-8160, CVE-2014-9683, CVE-2015-1420, CVE-2014-8173, CVE-2014-4943, CVE-2014-0196, CVE-2014-3153 vulnerabilities in kernel
2015-03-25
- Fix performance profiles
- enable KSM
2015-03-18
- New GPS HAL lib's
2015-03-14
- Fixed Bluetooth mac address
- Reduced minimal system size for resized partitions
2015-03-07
- New Adreno libs (userspace 3D drivers) - up to 20% faster 3D
- Fix in audiorouting (mic and headpnones)
2015-02-15
- Fixed RIL (Sim detection) on DualSim D325
- Fixed Mobile Data
2015-02-08
- Better implementation tap2wake. No problem with drop calls if enabled end call by power button option.
2015-01-31
- Implemented OTA updates. Starting with this version, here I will only write about major device specific changes.
2015-01-25
- CM updates, no device spcific
2015-01-19
2015-01-17
- Fix SmartCover and Magnetometer (compass)
- Fix key on ms323, thanks to @crutchcorn
2015-01-10
- No device spcific, only CM updates
2015-01-06
- More fix camera freeze
2015-01-05
- Fix camera freeze
- Fix keys for D320👎
- Add Display Color Calibration
- Add NFC firmware
- First universal
2015-04-11
2015-04-04
2015-03-28
- Fix NFC
2015-03-25
- enable KSM
2015-03-18
- New GPS HAL lib's
2015-03-14
2015-03-07
2015-02-15
- Fixed Mobile Data
2015-02-08
2015-01-31
2015-01-25
2015-01-19
2015-01-17
2015-01-10
2015-01-06
2015-01-05
- Fix camera freeze
- Add NFC firmware
- First universal
Because is for D320, D320n, D325 - vm03 can make nothing without device :/Lg l70 d325f8 sim card dont work please update!![]()
