Maslovicz
Is rooted, flash SuperSUhow to root cm 12 ??
Some posts moved. Some deleted. Let me know if I grabbed too much or too little.make a new thread. right now this thread is for cm12 and you're putting your issues here. I'll come back to help once you make your new thread. @Unforgiven can you clean up this thread please. this thread is not a help desk. this is for cm12.
^^^Here is where the moved posts went. Cheers
Yes, it is better to try twrp. Do not forget to do a clean install (format system and dalvik cache before installing rom).I'm on ms323 and still on 2-19 because every time I flash it with cwm I get the forceclose error. Do I need twrp for it to flash correctly n fix the force close error? Or?
You use twrp?Home button doesn't works on D320TR since build 0401 please fix it @vm03 I'm using 0328 without problems.
Make sure you flash aboot.bin... Without that you will fet Purple screen... Here arw instructions for installing custom recovery... http://androidforums.com/threads/cwm-lg-l70-d320-ms323-d325.871308/ after following those instructions, you will have cwm but just use flashify and install twrpShould I be able to flash twrp using "flashify" app, then rebooting in recovery with fastboot if I needed to? I just wanted to know if it woulf work correctly and if that's the correct way to do it. If not, someone please tell me directions or send me a link to flash correctly. Thanks
use this linkShould I be able to flash twrp using "flashify" app, then rebooting in recovery with fastboot if I needed to? I just wanted to know if it woulf work correctly and if that's the correct way to do it. If not, someone please tell me directions or send me a link to flash correctly. Thanks
Thank you, worked like a charm ^.^
That's not the correct way. Let me log onto my PC and I shall post the things you needShould I be able to flash twrp using "flashify" app, then rebooting in recovery with fastboot if I needed to? I just wanted to know if it woulf work correctly and if that's the correct way to do it. If not, someone please tell me directions or send me a link to flash correctly. Thanks
It flashed fine. The 4-11 update still force closes me though :cThat's not the correct way. Let me log onto my PC and I shall post the things you need
This would only work on a stock ROM as MLT service menu is bloat installed by LGLooking around I found This for LG G2 and I can confirm that it worked on My LG L70 D320f8 stock
1. Open your phone’s dial pad and type the following code: 3845#*<model number>#.
For example, type-
3845#*320#
I hope to make lollipop more smoother...
- 2. Doing this open the service menu of your phone. Scroll down to High temperature property settings and change the default value to ON
- 3. Now turn off your phone. Wait for about 15-20 seconds and then turn it on again
- 4. When your LG G2 boots up, you should experience smoother UI on it.
OTA updates for cm12.1? And what is causing me to drop off cell network sometimes? And could you fix the battery screen animation bug soon?2015-04-18
- Last build, more only CM12.1
For what model for l70. I'm on the d320n and camera worksHello, I am new to this community. I want to know whether failure of the rear camera is solved?
Thank you![]()
You can reboot to recovery directly from Flashify.Should I be able to flash twrp using "flashify" app, then rebooting in recovery with fastboot if I needed to? I just wanted to know if it woulf work correctly and if that's the correct way to do it. If not, someone please tell me directions or send me a link to flash correctly. Thanks
No. I'm using CWM. Should i flash TWRP?You use twrp?
Use TWRP it's better than CWM.No. I'm using CWM. Should i flash TWRP?
