Luan Lemos
My lg l70 d325f8 dont work sim card help me please
please what custom rom work for my device? link download pleaseBecause is for D320, D320n, D325 - vm03 can make nothing without device :/
All is working, but i think in all rom for your device is not working rear camera and sim detection.please what custom rom work for my device? link download please![]()
Please bring me link for download cyanogenmod for my deviceAll is working, but i think in all rom for your device is not working rear camera and sim detection.
Maybe Cyanogenmod 11.
For d325f8 is no build. You can try luck.Please bring me link for download cyanogenmod for my device
This rom works for LG L70 D325F, you just gotta exchange the aboot.bin file for the one for LG L70D325F, and then it will recognize your sim cards, I had this issue happen to me last monthFor d325f8 is no build. You can try luck.
Here:
http://androidforums.com/threads/unofficial-cyanogenmod-11-for-lg-l70-d320-d320n-d325.890205/
Cyanogenmod font work for my de viceFor d325f8 is no build. You can try luck.
Here:
thanks but you have other ROM custom download link?Unless you send a L70 D325-F8 to @vm03 , you're outta luck for custom roms. Sorry. Were already getting the MetroPCS variant (ms323) to VM03, maybe that'll fix some bugs for your version.Cyanogenmod font work for my de vicethanks but you have other ROM custom download link?
Yes, but better is CM12.1Sorry if I raise the ire of someone, maybe this question is stupid, but I don't have the answer ... This rom solve the problem, present in KitKat, referring to the downloading of data to SD? With all apps? I do not speak the language, I hope you understand
I have rooted my lg L70 but i can't unlock bootloaders and install CWM recoveryy. Please some one help me with a thread or link that works. Please guysfor the ones asking, these are custom roms and you need to root your LG L70 before trying to install any of these roms, and the videos posted can be helpful for rooting but we're in an English speaking forum so wont help because of the language difference.
This URL is great for learning to root LG Devices:
http://forum.xda-developers.com/showthread.php?t=2732311
Vague problem, but have you tried this? http://androidforums.com/threads/unlock-lg-l70-bootloader-unlock.862585/I have rooted my lg L70 but i can't unlock bootloaders and install CWM recoveryy. Please some one help me with a thread or link that works. Please guys
Thanks man, i'll try those and see if im gonna get it work. As per what i have done i've just root it but i also need to unlock bootloaders and install CWM or TWRP recocery and theres where my problem stands, anyway thanksVague problem, but have you tried this? http://androidforums.com/threads/unlock-lg-l70-bootloader-unlock.862585/
You don't really say what you have and have not done.
For above, you need LG Drivers:
http://www.lg.com/us/support-mobile/lg-MS323 Under 'software' tab.
Then you need to install ADB and Fastboot Drivers (I'm assuming you're using Windows):
http://forum.xda-developers.com/showthread.php?p=48915118#post48915118
Nobody.Hi guys, anybody got solved the problem in rear camera of the D325F8?
someone already sent an ms323 to @vm03 just the waiting game for it to get to russia is all.someone sent a D325F8 or MS323 device for VM03 for him to work in the rear camera bug not working?
Version/variant? If data doesn't work you need correct aboot.bin.Anybody help, my sim not work, I try do it
1. Download the SH File: http://d-h.st/dPZk. Then, put it in /system and change its permissions to 777.
2. Download SManager and find the file in /system and tap on it. Then, click su and net.
3. Disable WiFi, enable data and click run.
but not work, what I do?
