Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
1)Goto setting about phone click the build number 5 times and you will enalble developer options!
Then there will be an option called root access just click that and select ADB and Apps!that's it!
2)Goto setting then apps then you will see the dot menu at the top right side,there will be optioin called preferred install location
Just select the Removal SD Card option
I forget to ask this :
Can i Change download location to external?
@vm03, let's get that NFC working. I own d320n so I can test and provide needed files, but I don't have as much experience a you when it comes to fixing bugs in source. Tried it myself several times without success. That, plus very little free time I have... I thought we should collaborate via PM's. I'll do and test whatever you need :) You'll be my brain, I'll be your hands, simple as that :) What do you say?
If you need a dude that will test and has devices to test with, then I'm here! xD
Ok. Will try another.
Ugh. Now I'm not getting any errors with MD5. But now the recovery is failing to update. I wonder why. Is this happening to anyone?
Okay so I think I soft bricked my phone. I flashed the rom and gapps, but I forgot to format my internal storage. I tried reflashing back to stock but it wont work with fastboot.
This is what I'm getting.
Status
