You have to use right version of Aboot.binHas any of the D325 tried the new March 08 build? Everything except the RIL is working. Basically it can't detect the SIM. I tried reflashing, putting the SIM in after booting but nothing works.
Which one is the d325 patched aboot.bin? The one inside d320n folder?You have to use right version of Aboot.bin
Just reinstall your CWM using this file
http://androidforums.com/attachments/cwm-lg-l-70-d325-zip.83666/
I have this problem before, because using aboot.bin for D320. You have to use aboot.bin pathced for D325
(hint: If your model name on setting didn't say D325, you're using wrong aboot.bin)
Yup, removed battery, bricked phone, can you guys help me get in recov mode?
@vm03 RIL still not working (same with both versions, from 7.3. and 8.3.). All other running smooth and nice, even rear camera. Is there any way to compile some report and send it to you so you can check it. Maybe the problem is with aboot but i have no idea how to choose right one and how to replace it
I think I screwed up, When I tried to flash to revert to stock it just stopped and it went into a black screen, and two folders popped on my screen. Not the internal or sdcard....what should I do?...Try this...Post to let me know how it goes.
Just to verify..you are using LG MS323 aka L70?I think I screwed up, When I tried to flash to revert to stock it just stopped and it went into a black screen, and two folders popped on my screen. Not the internal or sdcard....what should I do?...
I have the MS323, and everytime I try, it goes into that black screenJust to verify..you are using LG MS323 aka L70?
Can you pull out your battery for 3 sec then put back in but dont power on yet..hold VolUp then plug Micro USB cord..dont matter can be wall charger, car charger, PC, the toilet..And what do you get?
Nope, No Fastboot or ADB.while at the black screen plug into PC..use fastboot to see if detected..also does your PC detect your phone while at black screen?
Try adb while you`re at it too
