SkullBitz
Member
But here's the problem, I never updated it. I just got it todaay this morning, flashed it, and it aint working...I tried to flash to stock but nothing.Wait. I must wait everytime 15 minutes when i make update.
what current version are you running right now cm12? ...I installed the last update before ota than installed the last ota update and installed and it went through... I also have ms323ms323 about 232mb and have checked the .zips
To fix that battery saving bug just plug in charger...Errm I am on the D325, I flashed latest build...but apparently SIM Card wasn't detected. Also when I tried using power-save screen went completely black and it became completely unresponsive. Force rebooted(took out battery) and now screen becomes black after showing booting screen animation for about 30 seconds. Anyone else having these problems?
I was on CM11 beforehand and have CWM recovery. After flashing the newer W5_20130308 Build I flashed Gapps Full package.
Huh?219.
I got itHey @vm03 not to bother or anything. But you took update 20150219 off the server. Mind uploading it again for people that have systemUI problems for ms323? Or do you not have the .zip anymore?
can you upload it?I got it
I installed it, but force-closes after the first reboot.Are you getting errors installing the (307) update for ms323 too? Geez I thought it was only me and someone else![]()
What Rom did you use?I need help..I can't revert back to stock, due to losing my recovery and my root permissions. I can't access the settings or anything, due to the version of my ROM being unstable...can someone help?
Try this...Post to let me know how it goes.DRIVERS(if you dont have them)
http://www.mediafire.com/download/b...leDriver_S51MAN312AP22_ML_WHQL_Ver_3.12.3.exe
Try this:
1:
Pull out battery..wait 3 sec..then put battery back in..dont power on..hold down the VolUp key and plug in via USB to PC..i dunno what you did so you`ll get one out of three..if your phone boots into fastboot use this[1http://www.mediafire.com/download/fki9p90s0ll6fq0/LG_Laf_Recovery_Multitool_v1.2.zip)(extract anywhere)2
http://www.mediafire.com/download/t3ear2a3kb8pe34/laf.img)(you`ll need this put it in same folder)3
run as admin *run.bat* and you`ll see your device in list and use Choice D and let it do its thing)](once done pull out battery and do same procedure until you get Firmware Update and continue to next step after this
2:
If you get Firmware update use this [1http://www.mediafire.com/download/9u3twt5xoj9trrt/LG_Flash_Tool_2014.zip)(extract anywhere)2
http://www.mediafire.com/download/dvp4196by3hutcq/MS32310b_00.kdz)(put it same folder)]..run *LGFlashTool2014.exe* as admin..on select type select 3GQCT..on phone mode select EMERGENCY..on Select KDZ File open the file you just downloaded from step 2 which would be *MS32310b_00.kdz*..click Normal Flash..you`ll get a pop up..leave all as is and click OK..itll run and let it do its thing..leave alone until it says complete..now pull out battery..wait 3 sec..put back in..press and hold VolDown key(or UP if it doesnt work)and Power..once you see the LG logo release power and press and hold again but keep holding VolDown key..if done correctly you`ll see Factory Reset Device?..use vol keys to make selection and power for OK..say YES..and let it do its thing..you should be back to stock in no time
3:
If you get Recovery..then you obviously flashed recovery to LAF partition..use recovery to factory reset..dont forget to format cache and dalvik cache. and use ADB sideload to flash ROM or if you have them stored in SD or Internal.
NOTE: If you want to go back to stock use steps 1 and/or 2
Just get older version...Has any of the D325 tried the new March 08 build? Everything except the RIL is working. Basically it can't detect the SIM. I tried reflashing, putting the SIM in after booting but nothing works.
