Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
Please help me to install/update the framework.. I have download, install and check the modules box and then I can't tap install/update framework.. If I just reboot, there will be no impact on the modules.
Just Reboot, thats what I do and everything installs and updates on its own. Xposed for Lollipop is still alpha and not supporting the install/update from app at the moment..........enjoy.
Which modules are working ?
I am using Gravitybox LP, Statusbar scroll to top, Lolistat, Lighting wall, Xinstaller, Xposed torch, Xtoast, Youtube background playback, PS Changelog, Boot manager, Battery History XXL, and their is much more you will just have to read the download description, version or visit the Xposed Module Repository(http://repo.xposed.info/module-overview) website for futher lollipop compatibility check.
what should I do after install and check module's box? I have try many modules and get nothing... Are you really using gravity box? And working?
Okay after using Music for a while it started crashing. Audiofx as well. It continues crashing even after force stopping. So for now they are disabled apps. Any idea. Should I do another clean flash or is some other way possible?
Bluetooth audio works like a charm with the latest updates on D320N, audio no longer dissapears, I think problem was CM specific
Same thing happened to me ..go to settings,apps, scroll to all find media storage and erase data on it and reboot..it will take a second for music to reload but it will happen
Status
