Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
Dear vm03, is it possible to make memory like in cm11 lg l70 port ?Cuz flashing it manualy is rly hard for newbies :) thanks.
Why you and many other, don't like use FolderMount for games and other fat apps??? It very nice app. Automaticaly find and mount game folders. And phone can full work without SD.
I like it , but if i want to install bigger app or game 1gb + its impossible . app needs to be installed in internal memory firstly then transfered to ext. This is how i do it (maybe its wrong) :)
ping vasy.ru
traceroute (tracert) vasy.ru
@vm03 I get this issue where after I flash CM12 (your build) whenever I go into Settings -> Security the Settings "app" crashes. Another thing is after I have locked the phone for the first time (lockscreen) and wake it up again, after that the System UI crashes. I get the "System UI has stopped" loop. When I look at "adb logcat" it shows that it's calling a function in the security-related stuff and the function doesn't exist. Something like "call to null object reference". I think there is a problem with the code related to security - either it's not there, it's not built, or something else. Is this an easy-to-fix problem? I'm going to reflash CM12 and get the error again, I went to CM11 for the moment. I was googling all last night looking for what happens here..
I have an LG Optimus L70 MS323
Can you show
ls -l /firmware/image/
Can you show
Okay, so first is the error I get in `adb logcat` when SystemUI crashes:
D/AndroidRuntime( 3737): Shutting down VM
E/AndroidRuntime( 3737): FATAL EXCEPTION: main
E/AndroidRuntime( 3737): Process: com.android.systemui, PID: 3737
E/AndroidRuntime( 3737): java.lang.NullPointerException: Attempt to invoke interface method 'int android.security.IKeystoreService.zero()' on a null object reference
E/AndroidRuntime( 3737): at android.os.Parcel.readException(Parcel.java:1546)
E/AndroidRuntime( 3737): at android.os.Parcel.readException(Parcel.java:1493)
E/AndroidRuntime( 3737): at android.app.admin.IDevicePolicyManager$Stub$Proxy.requireSecureKeyguard(IDevicePolicyManager.java:4627)
E/AndroidRuntime( 3737): at android.app.admin.DevicePolicyManager.requireSecureKeyguard(DevicePolicyManager.java:3491)
E/AndroidRuntime( 3737): at com.android.internal.widget.LockPatternUtils.getActiveProfileLockMode(LockPatternUtils.java:1506)
E/AndroidRuntime( 3737): at com.android.keyguard.KeyguardSecurityModel.getSecurityMode(KeyguardSecurityModel.java:96)
E/AndroidRuntime( 3737): at com.android.keyguard.KeyguardSecurityContainer.showPrimarySecurityScreen(KeyguardSecurityContainer.java:293)
E/AndroidRuntime( 3737): at com.android.keyguard.KeyguardViewBase.onFinishInflate(KeyguardViewBase.java:108)
E/AndroidRuntime( 3737): at android.view.LayoutInflater.rInflate(LayoutInflater.java:814)
E/AndroidRuntime( 3737): at android.view.LayoutInflater.parseInclude(LayoutInflater.java:916)
E/AndroidRuntime( 3737): at android.view.LayoutInflater.rInflate(LayoutInflater.java:802)
E/AndroidRuntime( 3737): at android.view.LayoutInflater.inflate(LayoutInflater.java:504)
E/AndroidRuntime( 3737): at android.view.LayoutInflater.inflate(LayoutInflater.java:414)
E/AndroidRuntime( 3737): at android.view.LayoutInflater.inflate(LayoutInflater.java:365)
E/AndroidRuntime( 3737): at com.android.systemui.statusbar.phone.KeyguardBouncer.inflateView(KeyguardBouncer.java:166)
E/AndroidRuntime( 3737): at com.android.systemui.statusbar.phone.KeyguardBouncer.ensureView(KeyguardBouncer.java:160)
E/AndroidRuntime( 3737): at com.android.systemui.statusbar.phone.KeyguardBouncer.prepare(KeyguardBouncer.java:155)
E/AndroidRuntime( 3737): at com.android.systemui.statusbar.phone.StatusBarKeyguardViewManager.showBouncerOrKeyguard(StatusBarKeyguardViewManager.java:115)
E/AndroidRuntime( 3737): at com.android.systemui.statusbar.phone.StatusBarKeyguardViewManager.reset(StatusBarKeyguardViewManager.java:147)
E/AndroidRuntime( 3737): at com.android.systemui.statusbar.phone.StatusBarKeyguardViewManager.show(StatusBarKeyguardViewManager.java:99)
E/AndroidRuntime( 3737): at com.android.systemui.keyguard.KeyguardViewMediator.handleShow(KeyguardViewMediator.java:1342)
E/AndroidRuntime( 3737): at com.android.systemui.keyguard.KeyguardViewMediator.access$1800(KeyguardViewMediator.java:117)
E/AndroidRuntime( 3737): at com.android.systemui.keyguard.KeyguardViewMediator$4.handleMessage(KeyguardViewMediator.java:1173)
E/AndroidRuntime( 3737): at android.os.Handler.dispatchMessage(Handler.java:102)
E/AndroidRuntime( 3737): at android.os.Looper.loop(Looper.java:135)
E/AndroidRuntime( 3737): at android.app.ActivityThread.main(ActivityThread.java:5256)
E/AndroidRuntime( 3737): at java.lang.reflect.Method.invoke(Native Method)
E/AndroidRuntime( 3737): at java.lang.reflect.Method.invoke(Method.java:372)
E/AndroidRuntime( 3737): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:898)
E/AndroidRuntime( 3737): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:693)
W/ActivityManager( 924): Process com.android.systemui has crashed too many times: killing!
When I ls -l /firmware/image I get permission denied - I need to figure out how to get root first over adb shell I think...
wow... there goes the 1 page... you could just do
...text...
...text...
sorry, I'm just fairly new to forums - also I'm a dork. you get root over adb with `adb root`. unfortunately it's in development options in settings, and the SystemUI loop started happening before I could get into Settings - I think I must reflash and try again.
Just goto settings -> phone info -> tap build number until it says "your something steps away from being a developer!"
then goto development settings and find root and adb section -> root and adb
pretty sure what your talking about
edit: oops didn't see your last post, try doing what @DevMyAndroid said. it will probably work. but the latest supersu zip and latest CM12 (the one that fc's alot) build caused a bootloop for me. so.
Ahh perfect! I thought the root access thing was in Security (which kept crashing on me so I thought I needed to use SuperSU somehow) -- I didn't have a Developer Options. It should have occurred to me, I just didn't think I'd have to tap on the build number in CM to get Dev Options. Anyway, root from adb is enabled now, thank you kind sir :)
@vm03 here you go:
root@w5:/ # ls -l /firmware/image
-r--r----- system system 372 2014-04-07 13:49 adsp.b00
-r--r----- system system 6760 2014-04-07 13:49 adsp.b01
-r--r----- system system 1 2014-04-07 13:49 adsp.b02
-r--r----- system system 4370064 2014-04-07 06:49 adsp.b03
-r--r----- system system 1164050 2014-04-07 06:49 adsp.b04
-r--r----- system system 586930 2014-04-07 06:49 adsp.b05
-r--r----- system system 640 2014-04-07 06:49 adsp.b06
-r--r----- system system 46460 2014-04-07 06:49 adsp.b07
-r--r----- system system 120 2014-04-07 13:49 adsp.b08
-r--r----- system system 7132 2014-04-07 06:49 adsp.mdt
-r--r----- system system 180 2014-04-07 06:49 cmnlib.b00
-r--r----- system system 6568 2014-04-07 06:49 cmnlib.b01
-r--r----- system system 102388 2014-04-07 06:49 cmnlib.b02
-r--r----- system system 4460 2014-04-07 06:49 cmnlib.b03
-r--r----- system system 6748 2014-04-07 06:49 cmnlib.mdt
-r--r----- system system 180 2014-04-07 13:49 isdbtmm.b00
-r--r----- system system 6568 2014-04-07 13:49 isdbtmm.b01
-r--r----- system system 34028 2014-04-07 13:49 isdbtmm.b02
-r--r----- system system 128 2014-04-07 13:49 isdbtmm.b03
-r--r----- system system 6748 2014-04-07 13:49 isdbtmm.mdt
-r--r----- system system 180 2014-04-07 13:49 keymaste.b00
-r--r----- system system 6568 2014-04-07 13:49 keymaste.b01
-r--r----- system system 16536 2014-04-07 13:49 keymaste.b02
-r--r----- system system 208 2014-04-07 13:49 keymaste.b03
-r--r----- system system 6748 2014-04-07 13:49 keymaste.mdt
-r--r----- system system 236376 2014-04-07 06:49 mba.b00
-r--r----- system system 84 2014-04-07 06:49 mba.mdt
-r--r----- system system 980 2014-04-07 13:49 modem.b00
-r--r----- system system 7368 2014-04-07 13:49 modem.b01
-r--r----- system system 97076 2014-04-07 06:49 modem.b02
-r--r----- system system 3845788 2014-04-07 06:49 modem.b03
-r--r----- system system 5990636 2014-04-07 06:49 modem.b04
-r--r----- system system 81920 2014-04-07 06:49 modem.b05
-r--r----- system system 165372 2014-04-07 06:49 modem.b08
-r--r----- system system 873708 2014-04-07 06:49 modem.b15
-r--r----- system system 529200 2014-04-07 06:49 modem.b16
-r--r----- system system 4111408 2014-04-07 06:49 modem.b17
-r--r----- system system 663456 2014-04-07 06:49 modem.b18
-r--r----- system system 73728 2014-04-07 06:49 modem.b19
-r--r----- system system 5376 2014-04-07 06:49 modem.b20
-r--r----- system system 2690896 2014-04-07 06:49 modem.b21
-r--r----- system system 1784384 2014-04-07 06:49 modem.b22
-r--r----- system system 116936 2014-04-07 06:49 modem.b25
-r--r----- system system 510244 2014-04-07 06:49 modem.b26
-r--r----- system system 164006 2014-04-07 06:49 modem.b27
-r--r----- system system 8348 2014-04-07 06:49 modem.mdt
-r--r----- system system 180 2014-04-07 13:49 playread.b00
-r--r----- system system 168 2014-04-07 13:49 playread.b01
-r--r----- system system 492684 2014-04-07 13:49 playread.b02
-r--r----- system system 9884 2014-04-07 13:49 playread.b03
-r--r----- system system 348 2014-04-07 13:49 playread.mdt
-r--r----- system system 372 2014-04-07 13:49 wcnss.b00
-r--r----- system system 6760 2014-04-07 13:49 wcnss.b01
-r--r----- system system 11212 2014-04-07 06:49 wcnss.b02
-r--r----- system system 32768 2014-04-07 06:49 wcnss.b04
-r--r----- system system 2827500 2014-04-07 06:49 wcnss.b06
-r--r----- system system 16 2014-04-07 06:49 wcnss.b07
-r--r----- system system 720896 2014-04-07 06:49 wcnss.b08
-r--r----- system system 36452 2014-04-07 06:49 wcnss.b09
-r--r----- system system 7132 2014-04-07 06:49 wcnss.mdt
-r--r----- system system 180 2014-04-07 13:49 widevine.b00
-r--r----- system system 6568 2014-04-07 13:49 widevine.b01
-r--r----- system system 116980 2014-04-07 13:49 widevine.b02
-r--r----- system system 772 2014-04-07 13:49 widevine.b03
-r--r----- system system 6748 2014-04-07 13:49 widevine.mdt
D/AndroidRuntime( 6322): Shutting down VM
E/AndroidRuntime( 6322): FATAL EXCEPTION: main
E/AndroidRuntime( 6322): Process: com.android.settings, PID: 6322
E/AndroidRuntime( 6322): java.lang.RuntimeException: Unable to resume activity {com.android.settings/com.android.settings.SubSettings}: java.lang.NullPointerException: Attempt to invoke interface method 'int android.security.IKeystoreService.is_hardware_backed(java.lang.String)' on a null object reference
E/AndroidRuntime( 6322): at android.app.ActivityThread.performResumeActivity(ActivityThread.java:2982)
E/AndroidRuntime( 6322): at android.app.ActivityThread.handleResumeActivity(ActivityThread.java:3013)
E/AndroidRuntime( 6322): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2396)
E/AndroidRuntime( 6322): at android.app.ActivityThread.access$900(ActivityThread.java:147)
E/AndroidRuntime( 6322): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1296)
E/AndroidRuntime( 6322): at android.os.Handler.dispatchMessage(Handler.java:102)
E/AndroidRuntime( 6322): at android.os.Looper.loop(Looper.java:135)
E/AndroidRuntime( 6322): at android.app.ActivityThread.main(ActivityThread.java:5256)
E/AndroidRuntime( 6322): at java.lang.reflect.Method.invoke(Native Method)
E/AndroidRuntime( 6322): at java.lang.reflect.Method.invoke(Method.java:372)
E/AndroidRuntime( 6322): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:898)
E/AndroidRuntime( 6322): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:693)
E/AndroidRuntime( 6322): Caused by: java.lang.NullPointerException: Attempt to invoke interface method 'int android.security.IKeystoreService.is_hardware_backed(java.lang.String)' on a null object reference
E/AndroidRuntime( 6322): at android.security.KeyStore.isHardwareBacked(KeyStore.java:318)
E/AndroidRuntime( 6322): at android.security.KeyStore.isHardwareBacked(KeyStore.java:313)
E/AndroidRuntime( 6322): at com.android.settings.SecuritySettings.createPreferenceHierarchy(SecuritySettings.java:221)
E/AndroidRuntime( 6322): at com.android.settings.SecuritySettings.onResume(SecuritySettings.java:353)
E/AndroidRuntime( 6322): at android.app.Fragment.performResume(Fragment.java:2096)
E/AndroidRuntime( 6322): at android.app.FragmentManagerImpl.moveToState(FragmentManager.java:928)
E/AndroidRuntime( 6322): at android.app.FragmentManagerImpl.moveToState(FragmentManager.java:1067)
E/AndroidRuntime( 6322): at android.app.FragmentManagerImpl.moveToState(FragmentManager.java:1049)
E/AndroidRuntime( 6322): at android.app.FragmentManagerImpl.dispatchResume(FragmentManager.java:1879)
E/AndroidRuntime( 6322): at android.app.Activity.performResume(Activity.java:6029)
E/AndroidRuntime( 6322): at android.app.ActivityThread.performResumeActivity(ActivityThread.java:2971)
E/AndroidRuntime( 6322): ... 11 more
W/ActivityManager( 952): Force finishing activity com.android.settings/.SubSettings
W/ActivityManager( 952): Force finishing activity com.android.settings/.Settings
In both crash instances (Settings->Security and the SystemUI loop) it seems like I'm missing android.security.IKeyStoreService as methods invoked off of it are null pointer exceptions. You asked about /firmware/image so I'm waiting to find out if I'm looking in the wrong area.. :>
I found this after digging for "android.security.IKeystoreService cyanogenmod", I had hoped it would work as it matches 5.0.2 but it did not: http://forum.xda-developers.com/showpost.php?p=58350489&postcount=223 This did NOT work for me. :>
PS: I've been keeping the phone from locking with the 10 hours of nyancat video on youtube. I can avoid having to factory reset again until it gets to be too much for me, lol.
Edit: I added the SystemUI crash log to keep this information together :>
Edit2: I added the error I get from adb logcat when I go to Settings -> Security
Edit3: added link to related but non-working solution
@vm03 here you go:
Install hi locker from google play and then you can lock your phone. But!!!! Don't do a reboot or turn off your phone or it will start crashing. :)
@vm03 here you go:
Try to reflash modem partition from various version of stok. I don't have more idea why keymate files don't open... :(
what should I do after install and check module's box? I have try many modules and get nothing... Are you really using gravity box? And working?
I am using gravity box for sure, but I have changed to PacLP yesterday, I had some problems with the new Xposed Alpha 2 update and cm12 so I changed to PacLP since when I had no issues. But I have not tried the new CM12 update. You should try it, it might have fixed the issue. I wanted to change back to CM12 today as it has more updates then PacLP. But I am to tried since last week flashing several builds from SlimLP, CM12 and finally PACLP. But here's what I have learned from flashing this different roms with xposed. You'll have to start fresh. Following this steps. Step 1 : Most Importantly Backup. Step 2 : Before factory reset or flash new rom in Philz Recovery, always mount data, system, ext sd. Step 3 : Then Wipe format data, cache, dalvik cache, system, (REMEMBER TO NOT WIPE EXTERNAL SD CARD) manually first, then use wipe for flash new rom in philz recovery or factory reset in TWRP. Step 4 : Flash your rom, flash PA LP pico gapps (http://forum.xda-developers.com/par...apps-official-to-date-pa-google-apps-t2943900) or use the one provided in this thread. I personally use PA LP Pico (recommended) gapps, as I find more system stability. You chose yours. Step 5 : flash newest SuperSu binary zip(http://download.chainfire.eu/696/SuperSU). Step 6: flash Xposed Lollipop Alpha 2. then finally reboot, remember to NOT wipe cache or dalvik or else you will have to reinstall xposed and might have lot of issues. I can personally confirm that I am using GravityBox LP without issues on PacLP. But you can try it on CM12. And let me know if the above steps work fin on it cheers. I have attached one picture of my custom build with GravityBox and some other Xposed modules. You can see the navigation bar in the picture as well, which is only possible with Gravitybox.......cheers......hope this helps.
Hi All,
Is the error "Unfortunately System UI has stopped" looping fixed or not.......
waiting for that so that i can go back to Cyanogen 12 Version having Android 5.0 lollipop
Also there is no Unknown Sources option in security for installing other third party apps.
Status
