Shahell Salvin Deo
I am on LG L70 D320n, Can you please tell me the steps you took, thanks.Link2sd works flawlessly for me on ms323 ☺☺☺
I installed new xposed version.. The modules work after soft reboot, and after that I enjoying and then if I just "reboot" or "power off" (not soft reboot),,, the modules didn't work.. Why just after soft reboot the modules can work perfectly?
Pm meDoes anyone know how to move apps into SD card? I have already tried link2sd, ms323
Thanks man ! You made my dayWrong thread - off subject...
(btw, xposed works flawlessly for me)
http://forum.xda-developers.com/showthread.php?t=3034811
[OFFICIAL] Xposed for Lollipop
http://forum.xda-developers.com/showthread.php?t=3030118
[DISCUSSION] Xposed for Lollipop
http://forum.xda-developers.com/showthread.php?t=3032184
Xposed Lollipop compatible Modules
cm-12-20150314-UNOFFICIAL-w5.zip is the stable one or not vm03....can you please confirm as i am willing to flash....but i dont want to riskCyanogenmod 12 for LG L70 D320 D320n D325
View attachment 79850 View attachment 79851 View attachment 79852
View attachment 79853 View attachment 79854 View attachment 79855
View attachment 79856 View attachment 79857 View attachment 79858
My port of CyanogenMod 12.0 for LG l70 D320 D320n D325. It is unofficial and unsupported by the CyanogenMod team.
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and CWM or TWRP recovery.
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Working:
Not working:
- Display
- touchscreen and multituch
- Hardware 3D rendring
- RIL - SMS, MMS, calls...
- Mobile data
- WiFi
- GPS
- Bluetooth
- WiFi, Bluetooth, USB tethering
- Audio - speaker, headphone, mic, routing, voip calls, etc
- Camera - photo and video
- SD card
- FM radio
- Hardware video decoding and encoding
- Sensors
- Double tap to wake
- SmartCover
Download
- NFC for D320n
- Rear camera for D325f8 and MS323
- Any others for unknown for me versions and revisions.
Since 20150208 see new builds on http://vasy.ru/CyanogenModOTA/builds/full/
(w5 for L70, w3ds for L40)
Gapps http://forum.xda-developers.com/par...apps-official-to-date-pa-google-apps-t2943900cm-12-20150131-UNOFFICIAL-w5.zip https://yadi.sk/d/QMPZZKBYePW7V md5: a57f787ff557856491b31ee6f0c8d73f
cm-12-20150125-UNOFFICIAL-w5.zip https://yadi.sk/d/X-zQjIYVeDnaW md5: 5f2bf656ff2d3b9bdb4675d0aa0dccea
cm-12-20150119-UNOFFICIAL-w5.zip https://yadi.sk/d/poRumQPXe6EUP md5: e79e26dad9f53aae0b5a8c7cd57bccb9
cm-12-20150117-UNOFFICIAL-w5.zip https://yadi.sk/d/lsnmUIs2e3y7a md5: 7080a2d5faf2a1551103ecd854809254
cm-12-20150110-UNOFFICIAL-w5.zip https://yadi.sk/d/dM7DnxOIdvWVXmd5: 6bb5fd368df7b1c53070a13b4bf9c682
cm-12-20150106-UNOFFICIAL-w5.zip https://yadi.sk/d/Mt0VGt3RdpJCY md5: abce7cee8b3a04051231603b2fa723c9
cm-12-20150105-UNOFFICIAL-w5.zip https://yadi.sk/d/IdZZrSyedoX37 md5: d375e7503b15559fab8d38eefd068fa1
cyanogen_recovery_w5_20150207.img https://yadi.sk/d/sxiBlfNfeZHaH unstable, no backup, wipe if enter by keys, slow bootup...
For full working OTA you need cyanogen recovery. If you use CWM or TWRP you can download OTA and install it manually from recovery.
Source
Kernel https://github.com/vm03/android_kernel_lge_msm8610
Device https://github.com/vm03/android_device_lge_w5
https://github.com/vm03/android_device_lge_msm8610-common
Proprietary https://github.com/vm03/proprietary_vendor_lge_msm8610
- Copy zip's to SD
- Enter to recovery
- wipe data
- install zip from external_sd cm-12<...>.zip
- install zip from external_sd gapps
- reboot
Donate
Non stock rom always risk and absolutely no warranty.cm-12-20150314-UNOFFICIAL-w5.zip is the stable one or not vm03....can you please confirm as i am willing to flash....but i dont want to risk
Ofcourse i agree ..... intially i got the error "Unfortunately System UI is stopped" booting error and i need to hard reset to enter recovery again......so i am asking is that bug is still with this or not and camera rear working or not and how about unknown sources option in securityNon stock rom always risk and absolutely no warranty.
On D325 all works, on D320n except NFC.Ofcourse i agree ..... intially i got the error "Unfortunately System UI is stopped" booting error and i need to hard reset to enter recovery again......so i am asking is that bug is still with this or not and camera rear working or not and how about unknown sources option in security
on LG MS323 please ?On D325 all works, on D320n except NFC.
As i know have problem on some device and no main camera.on LG MS323 please ?
ihave installed the 11th march file and i faced Unfortunately System UI has stopped working and it never gone ....thats why i got changed to MIUI ROM .........does any one confirm me is it still in the latest rom of CMAs i know have problem on some device and no main camera.
The last stable version for ms323 is 2-19ihave installed the 11th march file and i faced Unfortunately System UI has stopped working and it never gone ....thats why i got changed to MIUI ROM .........does any one confirm me is it still in the latest rom of CM
Thanks for the info, But I made the partition again using TWRP advanced partition (flashed recovery using flashify from Google Play Store), then reinstalled Link2SD and upgraded to premium. And that solved my problem of the "Link2SD invalid package".I've just followed instructions and experimented per app to learn what's best. Except for a few apps, I've linked everything and no loss in speed/performance. I'm using a Samsung card 32gb (4gb ext4)...
This is off subject on this thread, so if you need more help please pm me or dig further in proper forums ☺
http://forum.xda-developers.com/showthread.php?t=919326
Do you mean the CWM recovery, You can either use fastboot flash using ADB or if you can boot into homescreen try "Flashify" from playstore, but you will need the recovery from this Android Forum Website, cheers..............I hope this helps.please help me! I do not see CWM on cm12?
I always had this problem too with that Music Player, and I really like it... I removed it with Root UnInstaller to make some space, because it wasn't able to play my music, and now I'm using Poweramp...Okay after using Music for a while it started crashing. Audiofx as well. It continues crashing even after force stopping. So for now they are disabled apps. Any idea. Should I do another clean flash or is some other way possible?
Look what you have to do... You download (with the PC) the Game from the internet, then you put it's .apk on your SD.I like it , but if i want to install bigger app or game 1gb + its impossible . app needs to be installed in internal memory firstly then transfered to ext. This is how i do it (maybe its wrong)
