Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
Which version of CM you installed ......can you please tell me the filename so that i can use the same one for my mobile
Go to my post on page 65 the mega link will take you to build 219 which is the last stable build for all ms323 while newer builds only work for a few ms323s like mine .
Found the problem but can anyone tell me why MTP is not working :/
In Windows 7 Ultimate 64 bit the mtp driver just goes on installing -_-
I don't like do sd memory as on CM11, phone don't usable without SD card. I think about more useful method.
Can you make on first boot an option (Use SD as Internal / Use Default Memory Settings) ? With this, everyone with an SD can use it as an Internal Memory, and everyone without an SD can use the Default Settings..
And if you will add something like this... The files on the SD will be deleted after we will choose 'Use SD as Internal Memory' ?
I think about how do it or do otherwise.
Is it possible to create additional .zip or script or something, so it can be flashed before/after flashing CM, so it would be users choice how to use its sdcard (as internal or external), depending on whether or not he is flashing the additional .zip/script. It may not be logical from developers point, but just an idea...
Impossible by script. It required changes in framework.
Status
