Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
Hmm whats this flashing latest build after a full wipe then trying to flash a Gapps package gives me a error 70 insufficient system space....
Shall i not full wipe before flashing the newer build then?
hey
i have a problem with the launcher. apps in sd-card icon disappearing after restart, i had this issue on cm 11 too
L70 D325 cm12.
Lol
today i thinking about canceling my account here.
100+ emails from this site, because some people are so stupid and asking same question again and again...
Lol
Maybe I'm going too far, but I would definitely support stricter rules, like for example: make clear in op that repeated and off subject questions will be deleted at all times.
I mean, don't we know by now that it will never stop???
"Long Live the Developers"
@vm03
Since we do not want to remove emulated memory ROM stock! I made the changes in the stock boot.img however lack something else I do not know what it is, could be the framework?
If the Framework, where should I change? Because I have decompiled it and I can make some changes in his XML.
I've being used cm12 from delapanmb which released 18maret15.. It work very good untill now. But now i can't use Xposed Framework.. Anyone can help me..
look for the Xposed Arm Zip file and flash it with CWM Recovery, xposed not very useful being that most of the modules are for JB and KK roms
Xposed Arm Zip for Lollipop:
https://drive.google.com/file/d/0B2jrSeELuaqBcUhfQTBXVVZCUlE/view?usp=sharing
Xposed Lollipop Installer Apk:
https://drive.google.com/file/d/0B2jrSeELuaqBWlFBZjJYUFI5RTA/view?usp=sharing
if i install this rom to my lg l65 with root access an custom recovery installed. is it will work, or i need to modify build.prop? but i think that it wont work for me... :D
Follow these instructions:
http://androidforums.com/threads/un...0-d320-d320n-d325.893621/page-66#post-6907118
Copy the 'aboot.bin' patched for 'd325' to your "adb" folder ex: "C:\ADB"
Do reflash the "aboot.bin" usin adb
adb devices
adb push aboot.bin /sdcard/aboot.bin && adb shell
su
dd if=/sdcard/aboot.bin of=/dev/block/mmcblk0p6 bs=4096
reboot
Hi, i tried this instructions so many times, but can't get a success. so i used my method.
i think it will be helpfull for other D325 L70 users.
download & install
TERMINAL Emulator apk http://www.apk4fun.com/share/1203/
and FLASHIFY apk http://www.apk4fun.com/share/1191/
download and copy aboot.bin & stockrecoverymod.img files to internal memory
http://www.mediafire.com/download/7cqwjj85pgfd2y5/stockrecoverymod.img
http://www.mediafire.com/download/3h7os9zvadofhe5/aboot.bin
Open Terminal Emulator app and paste this command
Code:
su
then open Flashify app & click "recovery image". choose stockrecoverymod.img, reboot. thats it
I kind of need to us the rear camera, and I cant seem to be able to go back to the LG325 Stock Rom....any suggestions on where I can find a tutorial to go back....I didnt creat a backup of the rom but have all the stock firmware files as well as the kdz file
Just follow the unbrick guide, you'll be on stock in no time.
Status
