No device specific update. Only CM updates.What's new on 21 march update?
Thnks i found itFollow these instructions:
http://androidforums.com/threads/un...0-d320-d320n-d325.893621/page-66#post-6907118
Copy the 'aboot.bin' patched for 'd325' to your "adb" folder ex: "C:\ADB"
Do reflash the "aboot.bin" usin adb
adb devices
adb push aboot.bin /sdcard/aboot.bin && adb shell
su
dd if=/sdcard/aboot.bin of=/dev/block/mmcblk0p6 bs=4096
reboot
No service.Anyone knows what this exclamation mark shows? What does it mean?
The problem is the SIM card, Reinsert the card and reboot your phone, then try to send the MMS again.My LG L70 can not send MMS.
I use ROM 21/03/2015
I have the correct settings. I checked them according to the operator.
MMS could not send or from an earlier version ROM
Any idea what the problem is?
Replace your SIM card, Wipe Factory reset then try again.320n- In my case, it took 12 minutes to boot. I'll come back with more news.
Update:
- Mobile data does not work
- Home button works fine
- Camera works too
- Battery Saver gives lots of lag, even after I turned it off
When using CM11 not have this problem. Other data services functioning normally.The problem is the SIM card, Reinsert the card and reboot your phone, then try to send the MMS again.
Is CM12.1 even out yet?Is vm03 working on a CM12.1 port?
Edit: Can someone who has an account at 4da download the zip for CWM v2 and TWRP and mirror somewhere? Thanks. http://4pda.ru/forum/index.php?s=&showtopic=593516&view=findpost&p=33454295
You're not alone man, I can only transfer tiny files.. if big size, it will stuck at the middle and get error.. Hope fix mtp problem soonHy!
I installed the 03.14 release, and everything works fine, except when I connect my phone to PC, and try to copy files onto, it throws an error, and disconnect from PC. I can copy files from phone to PC, and I can push files to phone with ADB, but it doesn't seems right. Another bug is, that the SIM card relock itself within a few hour. Is there any solution? Perhaps just my phone is wrong?
Use MultiMount SDCardYou're not alone man, I can only transfer tiny files.. if big size, it will stuck at the middle and get error.. Hope fix mtp problem soon
New update:What news update on Cyanogenmod12 20150321?
READ THE TITLE FIRST>>>#foolquestion
How to remove 3g,h+,h at mobile data on status bar? It jerks
