Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
160 pixels not so much :) if no joke i don't know to fix it.
160 is pretty much value, while vga resolution is kinda out of date for phones these days. Anyway, I actually have workaround by using third party app, named lgCamera Pro, within the app you can set WVGA and 5 Mbps bitrate. But still, if this WVGA resolution can be obtained by stock CM12 camera, it will avoid the hustle. I'm keeping the hope, someday it'll fixed :)
I really need ROM without the emulated memory and with two cameras working properly. Only that nothing else! or if someone knew remove the emulated memory from rom stock ... it just would suffice me!
Like everyone has been saying, Moderators, please clean this thread.
Or even better @vm03 message the moderators to lock this thread and make a new one. This one is getting crowded and full of questions that have been answered 15x in a row.
Like really, 81 pages of questions?!?!?!
Battery for days!! Now let's spend it on streams.
You have just saved your battery, Save more by turning off your WiFi, downloading Go Power Master, Then save your battery more, Turning off all of these connections and anything that drains your battery, to make it 16 days.
As of Android 4.2.2, I don't know how much time to die the battery, also charging.
Heh nevermind i added it to my theme... Its easier... And what did you mean by that after you recover from softboot?
Edit: some wierd thing was happening to my phone yesterday and now on the place where Google search should be is empty and when i want to close apps it shows like this
Reboot your phone.
Did you find anything about how to fix the Location ? I really want to Test Smart Lock and use the GPS... And the Location is something 'basic'... How can we help ?
Some improvements with qualcomm location services are coming soon ;) I was also bothered with not-so-great location. Just wait for an update or two by vm03 and I hope we'll have a much better location :)
Status
