Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
Means the system partition size requirement is reduced (from about 1GB to about 500MB), so you can repartition the internal memory, and get the 2.6 GB free user data
But my friend said it can't back to stock ROM, because system left 500mb even dont enough for stock rom if brick flash must take special way to back stock ROM.
Temen lu bener. Klo dah di RePartisi gabisa flash stokrom via cwm. Harus flash via FlashTool
Your friend is right. You can't flash stock rom via recovery after RePartition, but you still able to do it with FlashTool
thank you so much for this awesome ROM.
but i have a little problem and that is that it cant search mobile operators manually. (still connects automatically).
and sometimes 3G is not stable and it switches to 2G.
keep on the good work. (I have L70 D320)
Please help.
i can not install play service or store.
i flashed gapps but it didn't work
++ never mind found the right gapps
you shroud install the minimal packeag about 90 mb
hmm i didint read forum past week . So here what i found
Music stopped working
Gallery stoped working
YouTube messed up
Lag spikes
WiFi sometimes cant connect , or turning off auto
Which one is more stable SlimLP or CyanogenMod 12 ?
pardon me for asking the dumb question, ive been using the 0219 version of this rom as my daily driver for a bit now (i have the ms323 and get the ui fc errors wtih anything newer), and have been using the net.sh script to bring my mobile data back in line when it drops out, is there a way to bring that in line on its own (the o3o7 update has the data fix listed in change log) or am i kinda stuck till the fc issue gets resolved? would it be possible to import files from a later version, or is mobile data linked deeply to other aspects that would make that more trouble than its worth?
oh and since i know this may come up, yes i tried flashing the cm12 datafix zip, and it made no difference to my particular situation
Neither of our builds are official. To be official, dev must join ROM team. Anyway, "unofficial" just a tag in our case, because we have same funcionality as we were "official" :)
Guys, go easy with 5.1. It WILL come on all ROMs we currently have, no need to hurry.
Lg l90 has update android lollipop. And l70 not yet. Besides status update lollipop l70 and l90 are same. ( maybe/maybe not )
I see @vm03 that you in cm11 insertrd sd card only (all of us will be thankfull becouse you can install link2sd from google play, and you can install apps into sd settings>default storage>external something like that, but i uninstalled it and changed to cm12, it is better), again gj for rom, nise suggestion (i even installed airborn 8 ;) )
Status
