Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
On apktool...
Recompiling : framework-res.apk
Started : 2015-03- 16:22:00,18
I: Using Apktool 2.0.0-RC3 on framework-res.apk
I: Building resources...
Complete : Yes
Success : No
Ended : 2015-03- 16:22:01,85
Do You Want To See The Logs? (y/n):
Log...
Log For : framework-res.apk
Log Type : Recompiling
Log Recorded At : 27 2015-03- 16:22:00,18
Log Recorded By : Advanced ApkTool v4.1.0 By BDFreak
W: Could not find sources
invalid resource directory name: D:\THI\Advanced+ApkTool+v4.1.0+By+BDFreak\AdvancedApkTool\3-Out\framework-res.apk\res values-?@-rES
Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [C:\Users\THIAGO~1\AppData\Local\Temp\brut_util_Jar_1731387116134867220.tmp, p, --forced-package-id, 1, --min-sdk-version, 21, --target-sdk-version, 21, --version-code, 21, --version-name, 5.0.2-7e913e6b74, -F, C:\Users\THIAGO~1\AppData\Local\Temp\APKTOOL1116277793732620853.tmp, -x, -0, arsc, -S, D:\THI\Advanced+ApkTool+v4.1.0+By+BDFreak\AdvancedApkTool\3-Out\framework-res.apk\res, -M, D:\THI\Advanced+ApkTool+v4.1.0+By+BDFreak\AdvancedApkTool\3-Out\framework-res.apk\AndroidManifest.xml]
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:437)
at brut.androlib.Androlib.buildResources(Androlib.java:374)
at brut.androlib.Androlib.build(Androlib.java:277)
at brut.androlib.Androlib.build(Androlib.java:250)
at brut.apktool.Main.cmdBuild(Main.java:225)
at brut.apktool.Main.main(Main.java:84)
Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [C:\Users\THIAGO~1\AppData\Local\Temp\brut_util_Jar_1731387116134867220.tmp, p, --forced-package-id, 1, --min-sdk-version, 21, --target-sdk-version, 21, --version-code, 21, --version-name, 5.0.2-7e913e6b74, -F, C:\Users\THIAGO~1\AppData\Local\Temp\APKTOOL1116277793732620853.tmp, -x, -0, arsc, -S, D:\THI\Advanced+ApkTool+v4.1.0+By+BDFreak\AdvancedApkTool\3-Out\framework-res.apk\res, -M, D:\THI\Advanced+ApkTool+v4.1.0+By+BDFreak\AdvancedApkTool\3-Out\framework-res.apk\AndroidManifest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:488)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:423)
... 5 more
Caused by: brut.common.BrutException: could not exec command: [C:\Users\THIAGO~1\AppData\Local\Temp\brut_util_Jar_1731387116134867220.tmp, p, --forced-package-id, 1, --min-sdk-version, 21, --target-sdk-version, 21, --version-code, 21, --version-name, 5.0.2-7e913e6b74, -F, C:\Users\THIAGO~1\AppData\Local\Temp\APKTOOL1116277793732620853.tmp, -x, -0, arsc, -S, D:\THI\Advanced+ApkTool+v4.1.0+By+BDFreak\AdvancedApkTool\3-Out\framework-res.apk\res, -M, D:\THI\Advanced+ApkTool+v4.1.0+By+BDFreak\AdvancedApkTool\3-Out\framework-res.apk\AndroidManifest.xml]
at brut.util.OS.exec(OS.java:89)
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:482)
... 6 more
@vm03
Please send me framework-res lollipop without emulated, i can't remove emulated without this, because i can't recompile framework-res! ;(
I don't know how to recompile... You can build CM12 from source with remove SD. But I see no reason to do it, when we have repartition tool or Xposed+XInternalSD.
Hi @vm03
I have a question. Why it contains userdebug in build info ?
Also i'd like to say that « only charge » doesn't work. When i connect a phone to PC and tap on connection method notification, then tap on « Only charge » phone disconnects from PC and connects back, option « Only charge » makes inactive back.
@vm03
Ok man, and about rear camera. Where should I start looking? /system/lib or Kernel boot.img?
I want to cooperate as I can!
From past pages, VM03 has stated that the MS323 and other models have a problem in the kernel. So start there.
While your at it fix Force FC's. Pretty sure everyone from the MetroPCS version wants that fixed first than the camera... still rocking the 20150219 build ;)
Ok my device is a D325f8 Brazilian Edition!
@vm03
If most have memory card !? Why do not you remove once the emulated memory? It only disturbs because if you can not play games with OBB files or DATA very large ... I would be better ...
Thank you vm03 for your work.I am using the 25 th march build on 320n ,no problem, very good and stable rom ,you work hard ,thank you very much.For large game obb use xpose with obb on sd module ,work like a charm.Thank you
@vm03
Ok stop!!!
Buy better device with big memory. You don't like internal memory? Use CM11. Or xposed with xinternalsd...
maybe sometime you can use your eyes with brain is very usefull tool and you can read this thread...
And edit:
Link for gapps not working, because author of gapps packages is an dumbass and delete this thread :(
Edit2:
Here is new link for gapps
http://forum.xda-developers.com/android/software/gapps-google-apps-minimal-edition-t2943330
I'm sorry if this is already posted.
But can somebody give me a link to repartition internal memory.
On the last update it stated that system memory now is repartition so we can repartition internal memory
BTW @vm03
thank's for amazing roms, can't belive I got Lollipop on my device
Ok stop!!!
And edit:
Edit2:
I have the GAPPS from that thread, I'll PM ROM devs for this device with it. I got alot of them before they went down. If anyone like the GAPPS from that thread. (like I did)
How did you installed it? Have you repartitioned something? Mine is stuck at the LG Logo
NO, just as usualy ;in cwm recovery, wipe data/factory reset than wipe cache partion ,in advance-wipe dalvik cache .Install rom ,install gaaps and that s all.If you want to update after to a new build date just flash the new rom ...
Status
