Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
how is the key combo ?
Power off device... Hold volume down + power... When lg logo shows release power button (hold volume button) and after a sec press power button... Factory reset confirmation will show up... Press yes few times (using buttons), it won't do factory reset. Or adb reboot recovery...
For f**ks sake its almost 4 am... I can't believe I am still awake...
adb reboot recovery don´t work
For those who having problem with low storage when installing games with data:
download data with pc-->copy data to the ext.sd to android/data(or obb)-->create a new folder in internal storage in same directory-->rename it to the downloaded game data folder-->open foldermount app & press + on top right-->enter a name then in second fild choose the empty data folder-->press √ then answer yes an and check last option-->press √ on top right and sey yes if asked anything-->now you will see a white pin button, press it and it will bicome green, the color of go as in let's ;)
I haven't been catching up to news, any news on FCing on MS323. I'm REALLY tired on being on the last stable build...
Also no one has said any news on MS323 in a while anywho...
Status
