ledosladoledi
Actually we could ask for help here... When he connects phone (in twrp recovery) it says device offline... Help us xD@zlaja84 we need your help asap in that one conversation......
Most probably faulty adb drivers or something, but vm is developer of twrp, not me :/Actually we could ask for help here... When he connects phone (in twrp recovery) it says device offline... Help us xD
Can you try to access adb in twrp?Most probably faulty adb drivers or something, but vm is developer of twrp, not me :/
Nope, not home.Can you try to access adb in twrp?
Write everything but without "adb"@ledosladoledi already tried it....... Can't use adb commands with that terminal
XInternalSD will replace the Internal Memory with the External SD ? And what happens if I remove the SD ?If remove emulated SD, phone not usable without SD card, and slower work at always. For big game's minimum 2 ways FolderMount and XInternalSD.
If you have just 100MB Free Memory and you UnInstalled some pre-installed apps, I think you should wipe everything...if you are updating cm 12 to cm 12 (but new version) then just install... maybe wipe cache and dalvik cache...
I think it's more easy with fastboot..
- adb push recovery.img /sdcard/
- adb shell
- su
- dd if=/sdcard/recovery.img of=/dev/block/platform/msm_sdcc.1/by-name/recovery
- exit
- exit
- adb reboot recovery
Yeah, about the twrp, there might be some BIG bugs... We can't confirm because there is nobody with ms323 to test... (Adb and that...)@vm03 You are AMAZING!!!!![]()
You should start a new thread for TWRP though.
I could maintain it like I do with PhilZ if you'd like
Really? Nobody? Gee... I feel the love. :'( It works perfectly btw...Yeah, about the twrp, there might be some BIG bugs... We can't confirm because there is nobody with ms323 to test... (Adb and that...)
What? You can see your device from adb devices while its in recovery??Really? Nobody? Gee... I feel the love. :'( It works perfectly btw...
I have that already xD
Yeah... Why... ?What? You can see your device from adb devices while its in recovery??
@DevMyAndroid can't...Yeah... Why... ?
Strange. Try a new cable. You know how the L70 is with it's cables. I only have one that'll work perfect for me@DevMyAndroid can't...
But it works when its booted in androidStrange. Try a new cable. You know how the L70 is with it's cables. I only have one that'll work perfect for me
Can't, u created it...@ledosladoledi add crutch to our tarp convo
Can't get it to work, i made TWRP folder, and inside theme folder, and copied zip file,renamed it to ui.zip, reboot to recovery and nothing happens...
