Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
Ok, It started up already. The message "Android is upgrading" is being displayed on screen now.
EDIT:
Now I just need to flash the GAPPS but it's giving me an error:
"Insuffcient space in system partition" and I tried to install the minimal
package which is:
pa_gapps-modular-mini-5.0.1-20150315-signed.zip
And it's 232MB, The console said something about using a smaller package
or uninstalling some apps via google config or something...
what do I do now?
EDIT:
package which is:
what do I do now?
If its mini package then how is it 232 mb??
lol, I just picked the one that said "mini"... which one of those on the image should I
install??
Gonna try the pico package first then since it's the smallest.
EDIT:
Gapps from the pico package installed just fine, Just received an OTA from cyanogen 12
but it failed the install. I gues it's because I have the CWM recovery installed?
Anyway, I just need to use flashify to install TWRP recovery right?
EDIT:
Ok tell us if it works
For now, Everything seems to work fine. Phone is faster than ever and the os is butter
smooth, my apps all seem to have no trouble at all.
Just some confusion with the menus since they seem to be ordered a bit differently but
I'll get used to it soon, The rom is pre-rooted too which is a god-send to me.
EDIT:
Mmmm... Tried to install the TWRP img with flashify but it did nothing, Apparently it
flashed the image but I still boot into CWM recovery.
BTW I just zipped the TWRP image file into a zip and flashed it, Should I just use Jeffta's
method that I used to flash CWM and just change the CWM recovery image with TWRP?
EDIT:
no, flash img file. it will work fine
I've try flash mini version on cwm, it says install aborted. Can I flash micro version, more little size from mini..
you can try but i have tried many gaaps this was the best.
plus if you flashed gaaps successfully and it didn't work u probably need a factory data reset.
P.S: I have used this package on both CWM & TWRP and it was fine
Thanks for the tip ShangulOmanghul! Just flashed the TWRP file with flashify and
no problems! Now I have TWRP recovery, Unlocked bootloader, Android 5.0 and root.
I'm all setup to play around!
Repartition system? Sorry but I haven't the foggiest idea on how to do that XD...
I used to have a optimus 2x and a program did the partitioning for me all the time... So, Does
the TWRP take care of that? Or how should I go about it?
I mean... I hate to always have around ONLY 400 MB free on internal lol... Damn LG...
You connect it to PC and just follow the instructions... It will do everything for you
I have lg l70 d320n I installed lollipop 5.0.2.
I can't root it
Help me to root it
Goto Settings -> About Phone -> Tap Build Number until it says "Something times until Developer Settings are enabled" and when it says "You have enabled Development settings!" Go back to settings and you'll see development settings. Go down until you see "Root Access" click that and select "Apps and ADB"
Your welcome.
Status
