First search net for rooting your devices it is easy also search for how to unlock your boot loader, then download flashify apk and twrp recovery in this from and flash it with the app.
Download ROM and gapps, go to recovery, wipe all data (make a backup first)
And press install. Choose ROM it is a zip file, now it take some time and then flash gaaps . whene it shown complete reboot to system.
You need to downgrade your firmware to root. D320n? PM @zlaja84 for downgrading. I don't know anything about downgrading the D320n model. Almost all L70's , any model got an update that pretty much broke root.I really cant find one in english and youtube vids dont really show the actual set by set process on how to do it for my model. and towerlroot says root not avialable for this model for some reason even though in front page of this thread it says this model can be rooted. Pls can someone just make a vid on how to do it properly like root, unlock bootloader, twrp, flashify thing and how to finally install cyanogenmod 12
So? It's your fault for flashing. Not ours. There's only like 2 ROMS that have everything working and those are based on Stock. Most devices don't have camera working at all. And some are lucky to get it even to work (Force Close Bug)Damn... Rear camera doesn't work on my L70 D320n... Now this is quite a deal breaker...
Now what? I take a lot of photos D: ...
Video Guides are not as easy as you think. So no one is gonna make it out of a snap of a finger. It requires ALOT of editing and if the process in the tutorial fails. Then there out of luck. So next time. Don't beg people to make tutorials. Lots of people don't have the time to do that kind of stuff. Worded guides are helpful as video ones.
Jump around threads. Or PM @zlaja84 , He's the D320 ROM creator and owner.I get it but i cant find any worded guides on how to do it and people here have rooted LG L70 D320n so i was just hoping one of them would tell me how they did it
Changelog
2015-04-11
2015-04-04
- Fix manual network search and select
- HW composer props for 8610
2015-03-28
- Fix NFC
- Memory perfomance optimizations
- Fix CVE-2015-1465, CVE-2014-8160, CVE-2014-9683, CVE-2015-1420, CVE-2014-8173, CVE-2014-4943, CVE-2014-0196, CVE-2014-3153 vulnerabilities in kernel
2015-03-25
- Fix performance profiles
- enable KSM
2015-03-18
- New GPS HAL lib's
2015-03-14
- Fixed Bluetooth mac address
- Reduced minimal system size for resized partitions
2015-03-07
- New Adreno libs (userspace 3D drivers) - up to 20% faster 3D
- Fix in audiorouting (mic and headpnones)
2015-02-15
- Fixed RIL (Sim detection) on DualSim D325
- Fixed Mobile Data
2015-02-08
- Better implementation tap2wake. No problem with drop calls if enabled end call by power button option.
2015-01-31
- Implemented OTA updates. Starting with this version, here I will only write about major device specific changes.
2015-01-25
- CM updates, no device spcific
2015-01-19
2015-01-17
- Fix SmartCover and Magnetometer (compass)
- Fix key on ms323, thanks to @crutchcorn
2015-01-10
- No device spcific, only CM updates
2015-01-06
- More fix camera freeze
2015-01-05
- Fix camera freeze
- Fix keys for D320👎
- Add Display Color Calibration
- Add NFC firmware
- First universal
Changelog
2015-04-11
2015-04-04
2015-03-28
- Fix NFC
2015-03-25
- enable KSM
2015-03-18
- New GPS HAL lib's
2015-03-14
2015-03-07
2015-02-15
- Fixed Mobile Data
2015-02-08
2015-01-31
2015-01-25
2015-01-19
2015-01-17
2015-01-10
2015-01-06
2015-01-05
- Fix camera freeze
- Add NFC firmware
- First universal
In LG-D320(L70)Changelog
2015-04-11
2015-04-04
2015-03-28
- Fix NFC
2015-03-25
- enable KSM
2015-03-18
- New GPS HAL lib's
2015-03-14
2015-03-07
2015-02-15
- Fixed Mobile Data
2015-02-08
2015-01-31
2015-01-25
2015-01-19
2015-01-17
2015-01-10
2015-01-06
2015-01-05
- Fix camera freeze
- Add NFC firmware
- First universal
Doesn't it say before you do it when it happens it's something with the ext/format if it asks you again? I used it and it showed that warning before creating the script.Running on 2015-04-04 and Link2SD is NOT working for me... Every time I try to create mount script it just reboots and when I open Link2SD it keeps asking me again and again
Nope. It asks as if I had never done it before.Doesn't it say before you do it when it happens it's something with the ext/format if it asks you again? I used it and it showed that warning before creating the script.
Have you checked the picture above? Edited it. Does it say that?Nope. It asks as if I had never done it before.
Huh.. I do get that reboot message (after creating the mount) but then why... Why would it not allow me to automount at boot? Man.... This + the bug of buttons is getting annoying...Have you checked the picture above? Edited it. Does it say that?
Root:I really cant find one in english and youtube vids dont really show the actual set by set process on how to do it for my model. and towerlroot says root not avialable for this model for some reason even though in front page of this thread it says this model can be rooted. Pls can someone just make a vid on how to do it properly like root, unlock bootloader, twrp, flashify thing and how to finally install cyanogenmod 12
I am on the newest build using LG L70 D320n and have no issues, I always update when a new build comes out. And Link2SD Plus works flawlessy. The Buttons work flawlessly as well. I think the problem could be between this two.Huh.. I do get that reboot message (after creating the mount) but then why... Why would it not allow me to automount at boot? Man.... This + the bug of buttons is getting annoying...
EDIT: Is there anyway to manually mount?
did you enabled root for adb and apps?Huh.. I do get that reboot message (after creating the mount) but then why... Why would it not allow me to automount at boot? Man.... This + the bug of buttons is getting annoying...
I think I know what happened... TWRP (I hate this abomination) decided to be a dick and format my EMMC to have ext4...did you enabled root for adb and apps?
and did formatted your sd card completely.
PM me if you need more help..
Good luckthnx i found those just a while ago before your post will try rooting tomorrow
I had this problem. Flash twrp 2.8.6.0 and install again.In LG-D320(L70)
Home button not work
Vibrate on touch not work
D325 does not have nfc.@zlaja84 I couldn't find the nfc switch button when access the settings menu on my d325, is this normal? Flashed the 20150411 using twrp 2.8.6 and still can't find it...
