Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
Then let
I'm not sure what`s going on, I know mine doesnt show because I removed the emulated partition and left it only linking all the apps to the SD card, it's working great so far with a different rom though (Paranoid),
With mine it keeps asking me what type of partition my second partition is
I've got this problem before.
do this.
format Entire SD with some tool. not just the partitions
make sure the second partition is primary
I use ext3 for myself....
What exactly do you want?
write in your native language if you can't write in English
si no se puede escribir en Inglés, escribir en su lengua materna (google translate)
If he, @Victor Gonzales , decides to that, that's cool but please post the English translation of it also, with google translate, to keep inline with the forum guidelines:
Language - English only: Please use English only on Androidforums. If you need, you can use a translating service to help with this. This assumes, of course, that you can even read this message! http://translate.google.com/
and so that others can assist ;)
Thanks ;)
Bugs in d320n"
Menu key isn`t working - work as back key
NFC not show in settings
MMS not work
20150411 Build
Manual network search work well :D
Sorry, i am using older recovery :P
Bugs in d320n"
MMS not work
20150411 Build
Hi,
menu key is working on my D320n - i have 20150411 too.
NFC is showing too, proof bellow.
Are u using new TWRP? If not, flash new TWRP.
Hey @vm03 This is off topic but it's Free Shipping for Russian Federation (guessing same as russia) a $30 LG L70 MS323 on Ebay! It might go quick. But might as well tell you.
The goods
Description it says that it is cracked but touch is working. Would it matter if it's cracked?
Maybe @shellboy32 can donate the $30 from @Keithman2567 back to you so you can get it much more easier? Also Ebay would bring a tracking number. Which I'm sure everyone wants to know where the package is going.
**EDIT***
It got sold :(
Can someone pls create a tutorial for me pls on how to install this rom onL70 D320n. I dont want to make mistakes by trying it out by my self. My phone is on stock and its not rooted.
First search net for rooting your devices it is easy also search for how to unlock your boot loader, then download flashify apk and twrp recovery in this from and flash it with the app.
Download ROM and gapps, go to recovery, wipe all data (make a backup first)
And press install. Choose ROM it is a zip file, now it take some time and then flash gaaps . whene it shown complete reboot to system.
Thanks, Also when I installed TWP recovery and tried to enter into recovery mode with
the rebooter app it only displayed a pink screen with some instructions for who knows what...
Should I flash the CWM recovery?
EDIT:
For some reason it seems I just can't get the recovery to install at all... All that
happens is that a pink screen whit the words "Demigod crash handler" appears
with 5 steps to do which I have no idea how are done.
The phone still works fine, Unlocked bootloader and rooted but without a recovery
I can't install roms...
Happened to me... How did you installed recovery? Make sure THAT YOU COPIED ABOOT.BIN TO SOMEWHERE... You should find instructions and files at cwm installation tutorial by jeffta... Just follow the aboot.bin instructions
can you point me to the thread of jeffta's CWM installation tutorial? Can't seem to find it
and I don't think I did a back up of any aboot.bin, I just followed the instructions on
unlocking the bootloader here...
Ok, I could do that... But the image on jeffta's zip is CWM renamed to stack recovery right?
So I just need to copy TWRP recovery image there and rename it the same as the image from cwm?
Status
