Root Unofficial CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
how long the last release (20151217) took time to finish when it flash? because its already taking 30 minutes now and still flashing. i'm using D325 ad TWRP 2.8.7. please help..
weird on my d320n worked, but i got issues with gapps error code 70 "executing updater binary in zip 'emmc/open-gapps-blabla.zip"
anyone else with the same problem, i tried all gapps none worked.
PS: witch one should i use ? arm or x86 ??
update info : after repair and reformat my system partition, tried to flash it again and still failed. the interesting message appear is when it failed it shows "the system partition contain unexpected file after OTA" (sound like that if i didn't forgot). so weird i think coz before do the flashing i wipe all thing (dalvik, cache, data, system and also internal memory).
That happened to me yesterday. I wiped dalvik, cache, data and system but it still says error executing binary... unexpected file after OTA. When I tried to install 12/10.
Maybe this doesn't make sense but what I did was wipe all partition (except Internal storage) then flash 11/15 (since it's the only older version that I have). As usual it failed. Then I wiped the partitions again then installed 12/10 (I haven't downloaded the latest version yet so I'm using 12/10), still failed. On my last attempt I wiped data, dalvik, cache, system, then wiped system again and it worked.
I forgot to screenshot the TWRP log but that's what I did to get it working. By the way. The ROM will boot even if it says failed. But it will have app crashes.
Here's my bug report :D
- can't adjust FM Radio volume
- can't deactivate SIM Cards on Settings. Returns with a pop-up "Deactivation failed"
- can't disable Vibrate on touch
- Screentimeout: screen brightens instead of dimming before timeout(about 3-5 sec before screen turns off). Noticeable if brightness is set to lowest.
- CM file manager doesn't have an option for root access. The fm from cm12.1 have this option. (Not an actual bug, just a missing feature)
13.0 is still better than 12.1 when it comes to battery life. I have 5 hours of screen-on time on 13.0 while on 12.1, the closest I can get is 3 hours.
sd not understand why the internal memory as sometimes works well and others not in the compilation of 17 pc sd showed me and I reinstalled a few times and 2.20 gigabytes internal memory always appears nothing
got a boot loop when I updated to 12/19 should I have installed that cm recovery image as well. Or just do a fresh install?edit: latest update12/20 works well. Only issues are the speaker phone volume is really low and caller on other end hears themselves echo only way around it for me is to use Bluetooth, oh yeah and Twitter crashes constantly
Okay guys I'm new to this forum so I have a LG L70 D325 Dual Sim mobile and I flashed the 20.12 CM13 build using TWRP but after flashing it, it won't detect SIM cards.
Plus the most astonishing fact is that it shows "D320" in the "About Phone" Settings menu.
That led me to think that I'd accidentally flashed the wrong bootloader in the beginning.
I'm stuck here guys, can anyone tell me what I've done wrong?
Download mode doesn't work either as it shows some error when I tried to flash stock KDZ file
I'm also the owner of LG L70 D325 (Dual Sim) and everything works fine...
Android can't detect your SIM because you used aboot.bin for D320 (during CWM/TWRP recovery flashing), and not D325...
Here are some resources:
-CWM Recovery with aboot.ini for D325 & D320n
-TWRP Recovery with aboot.ini for D325 & D320n
*If you are using D320n then replace aboot.ini from folder "D320n Aboot"
-PicoGapps (great for L70)
-Working Stock Firmware (KDZ) for LG L70 D325 *Alternative link
-LG Flash Tool
For any other help or resources, feel free to ask me here or on Skype (nenad147)
I have a little problem... when i try to install gapps after cm 13 it tells me i don't have enough memory... i am using CWM by the way.
Now clean your phone (factory reset) clean davik and cache also... Don't exit recovery! Then, flash CM13 ROM and immediately after it's completed,go back and flash gapps from link I posted above or click on this link !
some body have problems with the root? i try the official and unofficial cm 13 for lg l320n, and there is no way to have root, i enable it from developers option but doesnt work, and i have another problem, wen usb debugg it's on, my windows give the blue screen.. some one have this problems to?
Don't use CWM recovery... That's why you can't get root access... Use TWRP instead ;)
Check this out
