i will try it on 12/13/2015 and no i haven't tried the ota.When giving wing Micro SD format to internal storage, the partition is damaged Any solution?
Do you have working OTA update, because it's not working for me?
So i am going to say that i am sorry the adopted storage doesn't work on my phone either on the latest update ('s).okay here were my results if this help's i hardly installed anything onto 12/10/2015 update, then tried adopted storage this is on ms323 btw. and it worked great. then i un did it and that is purely because i was on an old 2gb sd card to test. now i just ordered a new one.
i will try it on 12/13/2015 and no i haven't tried the ota.![]()
Good work vm03, as usual. Now, my observations: overall a good rom, for an early release. Only problems that I had were random call drops (I already enabled "end call with power button"), and offline charging, which I think works, but the screen is completely black and you cannot wake it up. Oh, charging seems to be slow, it even says so on lockscreen, "slow charge", lol. I tried switching from just charging to mtp in developer settings, but it stayed the same.
Again, very good job vm03I know that when there's new device three and kernel there has to be some initial bugs... Can't wait to see where this goes. I'm gonna use and adapt this new tree for my roms in future
Thank you!
I gave up on it. Based on outdated version of android, not open sourced, plus I have other projects which I need to start ASAP, as well as private life, so.... I'm sorry, maybe someone else will port it one day.How 'bout your Unofficial MIUI ROM? Have you continue? I still wait... (for now, I using CM13 on my phone and my wife's phone. But, if MIUI is available, maybe she will happy to try it...![]()
It says Charging slowly but my actual charging time is just under 2 hours. Same on stock and cm12.1.Good work vm03, as usual. Now, my observations: overall a good rom, for an early release. Only problems that I had were random call drops (I already enabled "end call with power button"), and offline charging, which I think works, but the screen is completely black and you cannot wake it up. Oh, charging seems to be slow, it even says so on lockscreen, "slow charge", lol. I tried switching from just charging to mtp in developer settings, but it stayed the same.
Thank you!
Omg, I should have waited, I reverted to aospIt says Charging slowly but my actual charging time is just under 2 hours. Same on stock and cm12.1.
It serves the function of recording? In my case the camera does not save the videos. The stock camera, and google camera, "simulates" record it, but no video file, after stop recording, but i installed others apps and directly goes wrong and shows an error message saying "recording failure video"rear camera running at f8 ..uhuuuuuuu
If I do some, i write, otherwise only upstream updates.hey @vm03,
could you please create an change log to say the major and minor problems for this ROM exactly like the CM12.1 on vasy.ru host respectively ?????
As upgrade? Since the phone settings says that no updates.if I none wrote, only upstream updates.
