Great, now where are the step by step instructions for Unrevoked for those of us who are new to this.
There should be a link to instructions on the site....otherwise check out xdaforums I know they had a good set of instructions over there in the evo section.
Rooting Using Unrevoked 3.21
This is what I did to root my Sprint Evo 4G with froyo 2.2. I got these steps from various places but it worked just fine.
- On my computer I uninstalled HTC Syn. (Using control panel and Add or Remove Programs. I did not uninstall the HTC drivers)
- I installed the HBoot Driver by following the instructions on this page public:windows_hboot_driver_install [RootWiki]
- From this page, unrevoked3 recovery reflash tool, v3.21 I downloaded a copy of the reflash_package.exe file and save it to a folder on my PC.
- From the page http://androidforums.com/incredible...ked-3-rooting-stock-incredible-evo-2-2-a.html I then followed the instructions under
I had the stock OTA Froyo from Sprint and I just used unRevoked in the same manner as described in post #8. I uninstalled HTC Sync as well as DoubleTwist and everything worked like a champ.
It does appear as if the process is being done twice but the second time is the installation of the Clockwork Recovery MOD.
Tested by using ShootMe and installed Titanium Backup and both worked fine.
Now I just have to figure out where to go from here...
