Root Unrevoked not working?
nschiwy
Ok, so i have a HTC Droid Incredible which i recently downgraded to the android 2.2 software in order to root using unrevoked and for some reason it doesn't work...
Android Version: 2.2
Baseband Version: 2.15.00.07.28
Kernel Version: 2.6.32.17-g9a2fc16 htc-kernel@u18000-build-149 #1
Build Number: 3.26.605.1 CL264707 realease-keys
Software Number: 3.26.605.1
Browser Version: Webkit 3.1
PRI Version: 1.28_002
when trying to use unrevoked i get the error message from the program saying "failed to root. is your firmware too new?" which is doesn't make sense to me considering it is the 2.2 firmware. also a lot of times the phone will turn off during the "root" process and thats when i get the failure message, other times when i keep the screen on during the process, i get an error message from my phone explaining that some software related to unrevoked has crashed and to force close the app.
Anyone who spots anything right away i apologize for making a new thread for this but i couldn't find anything else that was about the original droid incredible AND about unrevoked not working, but either way i will appreciate any advice. I am open to using ADB to root, if there are other methods that i can use rather than unrevoked.
Thanks!!
Thanks!!
I'd just try rebooting the phone and the computer and try again.
I couldn't even tell you how many times i've rebooted my computer and phone over the last couple of days trying to get it to work haha good advice though
Weird, that usually does the trick. Try downloading unrevoked again, and run it a few times in a row if it doesn't go the first time.
Also some people have better luck with starting the program first, then plugging the phone in.
Ok so one thing ive learner is there is a huge difference between unrevoked 3.22 and 3.32. In order to root the incredible 1 it must be 3.22. Since the government shut down all the file hosting sites a lot of links have been broken for downloading the correct version, and I didn't know it was a big difference, usually there is backwards compatibility. Anyway I got to the point where it flashes clockwork recovery to my phone and then it stops. Is there something I am supposed to do or am I just being too impatient? Since its on therenow though, could I just flash the Rom I want or do I still need root access first?
Unrevoked 3.32 should work on the 2.2 software. It can be found at unrevoked still.
If you boot your phone and have the superuser icon in your app drawer, you should be okay to just install rom manager from the market and use that to flash clockwork recovery. You will need to make sure that your phone is s-off though (in hboot). But you need root access before you can proceed with anything else.
+1 on the above advice. 3.22 is used to gain temporary root access while on gingerbread. 3.32 is what you want to use in your situation. Theoretically they should both work but you may as well remove the possibility from the equation.
If that is the case then i really don't know what to do because when i use 3.22 i get stuck at the recovery screen and unrevoked says "booting in recovery" and when i use 3.32 i get the "failed to root. is your firmware too new?" error. Is it possible that my hboot is too new? my phone has hboot 0.92 which i understand is an upgrade that was sent at some point from hboot 0.80
any suggestions..?
any suggestions..?
Your hboot is fine... When you say your phone gets stuck in recovery... is it clockwork recovery or the stock recovery? If you are getting stuck in clockwork, you can manually flash superuser and s-off.
Does your hboot still say s-on at the top left of the screen?
hboot says s-on, and yes i am getting stuck in clockwork recovery. can i just put files on my sd card and push them then?
Please Note that this post is outdated and will only work for those with .92 hboot
So, This is the second time I’ve tried to make this post and I feel like I should have known better than to make a giant post like this and then hit submit before copying it to word or something but anyway…..
I thought that I have been through so much to finally get this rooted and have my ROM installed that I thought I am certainly not the only person to have had this problem and I would organize a full instruction guide to Downgrade, root and flash when you have troubles with unrevoked for people who have had similar troubles.
NOTE: I AM NOT RESPONSIBLE FOR ANY DAMAGE YOU CAUSE TO YOUR DEVICE, THIS GUIDE IS DESIGNED TO HELP DROID INCREDIBLE USERS WHO ARE HAVING TROUBLE ROOTING THEIR PHONES AND I DO NOT KNOW THE EFFECTS A SIMILAR PROCEEDURE WOULD CAUSE TO OTHER PHONES.
First things first, I want to give credit where credit is due. Scotty85 of these forums wrote a large portion of what I am about to tell you and I am simply copying it and I will give you links to his original posts so he gets credit.
Step 1: Downgrade your phone
If your phone already has Android 2.2 on it then you can skip to Step 2
The HTC Incredible cannot be rooted unless it is running android 2.2 froyo, so the first thing you must do is downgrade your phone: I will copy the instructions to here so they are all in one place but here is a link to the original post by Scotty85
http://androidforums.com/incredible-all-things-root/427344-how-root-2-3-4-downgrade-get-s-off.html#post3308718
I will provide you with new links because a lot of the ones on Scotty85’s post are dead
First Download These Files:
Hboot Drivers for The droid incredible – from unrevoked
Mini-adb_inc.zip from mediafire
PB31IMG.zip from mediafire
Now, follow the following instructions:
3)prepare to downgrade
-extract the mini-adb_inc .zip. place the extracted folder on the root of your c\ drive. it comtains mtd0,flash_image,and some adb tools.
-extract zergRush.zip. take the image inside,and either copy/paste or drag it into your mini-adb_inc folder
-place the PB31IMG of 2.2 on the root of your sd card. rename PB31IMG. now is a good time to verify that your SD card is formatted "FAT32" by right clicking on the drive that is your phones sd card,then click "properties". if you find your card is formated anything else,youll have to re-format it. start by backing up all files to your PC as reformatting WILL wipe it clean. using your PC,do a full format to FAT32. you can then transfer the files back. *this is important-as your phone will not find the downgrade PB31IMG unless your card is formatted to FAT 32,and the file is correctly named.
4)downgrade with adb. make sure your phone is charged to 100% before starting.
-on windows 7,click the start bubble and type "command" in the search box. this should open a small black command window. from this point forward,all code will be in bold so you know what lines to copy and paste(or type,if you really want to type them all in). additional comments will be blue,and should not be copy/pasted. please note that each line is one command. copy/paste it into the prompt in your command window,and push enter. one line at a time.
at the end of the post,is a copy of my session,to show what the outputs of the entered lines should look like. hopefully,its a little less scary when you know that youre getting the right responses to the things you enter.
-make sure phone is plugged in and usb debugging checked on in charge only mode
-at the promt in your command window:
cd c:\mini-adb_inc this should change your command promt to "mini-adb_inc",indicating youre using that directory.
adb devices this should output your phones serial number,indicating its recognized
md5sums mtd0.img it should output a few things.at the end you should see this number 34307be744275f1db1dd16af04c37839
md5sums flash_image again,it will output some things,then you should see this number: 0098a7dd6600b55fac34fc6645be5d7a
md5sums zergRush again,output stuff, then this number:4a32187446c284c2b975845f3ab9ffc4
*all those numbers must match exactly. if they do then you can procede.
adb push zergRush /data/local/
adb shell this will change your promt to a $
chmod 755 /data/local/zergRush
this will cause zergRush to start,and it shoudl say "found a gingerbread!" followed by a bunch of other funny stuff.
last thing it says will be: Killing ADB and restarting as root... enjoy!
you should then be returned to your "mini-adb_inc>" prompt
adb push flash_image /data/local/
adb push mtd0.img /sdcard/
adb shell your prompt should change to a #
cd /data/local
chmod 0755 /data/local/flash_image
cd /data/local
./flash_image misc /sdcard/mtd0.img
you can now downgrade back to 2.2,so you can run "unrevoked forever" to regain s-off
exit to get out of your adb shell,and back to the "mini-adb_inc" prompt
adb reboot bootloader this will boot your phone to "fastboot" select "bootloader" with the power button.
Now what you need to do is place PB31IMG.zip onto the root of your sd card and run hboot by when turning on your phone holding down the power and volume-down buttons at the same time. It should automatically find the file and ask if you wish to update and you just need to select “yes”.
Step 2: Flash Clockwork Recovery to your phone
You now need to download a few more files and place them somewhere that will be easy to find.
Unrevoked 3.22 from Mediafire – NOTE: if this link ever becomes broken, you must use version 3.22, 3.32 will NOT work.
Clockwork 5.0.2.0 from PvilleComp.com – make sure you use clockwork 5.0.2.0 with md5: e8ac35ddc1c37000bb0852d1f380b5bb
Next, run unrevoked 3.22, as an administrator if you can. And click file>Custom Recovery… and select the .img file which is inside the Clockwork 5.0.2.0 .zip that you downloaded, you may need to extract the folder first.
Next you can plug in your phone and select charge only and then go to Settings>Applications>development> and enable debugging.
Unrevoked should now recognize your phone and bring up a warning dialogue. Click ok and Unrevoked will run and flash Clockwork 5.0.2.0 to your phone. Do not touch your phone until you see a terminal-like screen on your phone in all blue text on a black background.
At this point just click “reboot system now”- you can navigate clockwork using the up and down volume keys and use the power button for “enter” or you can use the scroll button at the bottom of your droid incredible to navigate and center-click for “enter”.
Step 3: Rooting your phone
You will now need to download a few more files and place them on the root of your sd-card
Superuser.zip – found on androidsu.com – simply select the version of superuser.zip that matches your OS, 2.2 Froyo.
Unrevoked forever – from unrevoked.com – look for the unrevokedforever.zip file download
Like I said, place these files on to the root of your SD card at this time using the mass storage feature of your phone when it is booted into android.
Now, boot your phone into clockwork recovery mode. Simply turn off your phone and hold power + volume-down and it will start the hboot and then select “recovery” using the volume keys to navigate and the power button for “enter”
When booted into clockwork navigate to the “install zip from sd card” option and then find the superuser.zip file that you put onto your sd card. Select yes to install and clockwork will install superuser and root your phone.
At this time your phone is rooted, and if this is all you wanted then congratulations, you’re done! Simply click on “reboot system now” and enjoy your superuser powers responsibly
However, if you want to someday in the future flash a ROM to your phone go ahead and use the same procedure you used to install superuser.zip to install unrevokedforever.zip, this is simple to switch the phone from s-on to s-off, which means that the security is off and it will allow you to install unsigned ROMs to the phone (one’s not signed by HTC)
You may now click “reboot system now” to reboot into android.
Step 4: Installing a ROM
Find a ROM from Cyanogenmod or your favorite developer such as and put it onto the root of your sd card.
At this time you have two options for installing a ROM to your phone: you can either manually go into clockworkmod recovery and wipe the cache, data, and system of your phone and then use the “install zip from sd card” and install the ROM
OR you can install ROM manager to your phone (can be found on Google Play, formally Android Market) and install from there. All you need to do is use the app to reflash Clockwork and then select “Install ROM from SD card” and it will do all of the work for you. You can choose to backup your old ROM or to wipe the cache, but after this runs and completes you will boot into your new ROM.
Note: if you format your sd card before this process and have only the ROM on the card it will run much faster.
You’re done! Congratulations! You may have a ROM that does not have google apps pre-installed but there are many guides online for installing the android market and google apps. For example, for cyanogenmod you can just flash a gapps.zip specific for your version using clockwork and it will push all of the apps for you.
Enjoy your now rooted and flashed phone, and as always, root responsibly.
Is there another location for ZergRush? I'm getting access denied errors from the link on xda, and I've spent *far* too much time tonight trying to get to root.
As far as I know, ZergRush doesn't work on gingerbread. Can you share a little information about your phone to get you fixed up? What android version? if you load hboot, what is the information displayed at the top? hboot version? s-on, s-off? I should be able to help you out if you give me a little information and let me know what kind of symptoms you are experiencing at which steps.
Zergrush is meant for gingerbread.
I was getting the same error from the links on xda. It may be back up by now.
If this method isn't working for you:
You can also use this method:
http://androidforums.com/incredible...ow-unlock-downgrade-achieve-s-off-htcdev.html
sorry, I confused the zergrush script with the app that used to be able to root devices a while back that also started with a Z!
No worries, guys. I started over, and managed to root and S-off this time. Don't know what I did wrong last time.
So, now I'm running stable Cyanogenmod7. :) Tried Miui, didn't like it.
u mean z4root? only gives temp root to s-on users
z4 can install CW on s on phones if your persistant ;)
my junk spare inc wouldnt run unrevoked,and i was able to get cw installed with z4 and rom manager,then flashed unrevokeds forever patch.
a long time ago there was a thread,and the user said he just flashed cw over and over from rom manager- 10,20,or some absurd number of times,and it worked. so as i sat watchin tv one night,i flashed cw from rom manager over and over. couldnt even tell you how many times. finanly it froze(its junk-not cause of the repeated flashing). pulled the battery and entered recovery thru hboot and lo and behold there was clockwork :D
if you have trouble with z4,you can use the htc supertool to prep the phone(temp root with zergrush) and then permantly install su. after that try and install cw with rom manager.
