Root Unrevoked with 2.29.405.5?
arkazain
As the title says, will I be able to root my Desire (2.29.405.5) with unrevoked 3.22?
Here is some more info:
BRAVO PVT1 SHIP S-ON
HBOOT-0.93.0001
MICROP-031d
TOUCH PANEL-SYNT0101
RADIO-5.11.05.27
Just want to make sure before I mess things up XD
I just found this on the unrevoked website:
At this time, unrevoked3 works on all versions of the supported phones, thanks to the exploit discovered by Sebastian Krahmer.
This should mean that I won't have any problems right?
well not exactly
it doesnt work with the WWE_ASIA build which is new so maybe theyve patched the exploit
only way is to try it out and see.
well not exactly
How new? I bought my Desire this summer, and how do I check it?
And while I'm at it, is there a way to backup things like game progressions, app preferences and things like that without root?
the htc_WWE_ARA build is higher than that one. its 2.32 however it cannot be rooted
I havent seen anyone say there is or is not a problem with this build or 2.29 but im just letting you know that it might not work as it seems HTC have patched the exploit in the ARA build intentionally
