Root unrevoked3 and apps2sd
redninja
Member
hey guys, i unrevoked3 my 2.2 evo. installed netarchy over custom rom for fps, which worked fine.. installed the apps2sd enabler, but am unable to move the adobe flash over to sd. So am now wondering if it is fully rooted or not or if anyone else is having problems moving to sd card, also am using the stock app manager to move them over. thanks
I believe Adobe Flash is a plug-in and can't be moved to your SD card. Sounds like you're fully rooted if you were able to install a custom ROM and kernel. If you're really not sure, the System Manager app can tell you on its Device Info tab.
not sure if this is true with flash but I do know you can't move ALL apps to sd....
like plug ins....and apps that are older and haven't had that option enabled
i'm rooted, stock rom- netarchy kernel. I was under the impression all apps copuld be moved after root, with the use of "move2sdenabler", even says you are able to move the adobe flash, through the stock app management.
