Root unrevoked3 cause boot loop??
dj.GETAFIX
is it tru that rooting with unrevoked3 causes a boot loop with adsd+ roms
im on leedroid 2.2b and have had some rebooting a lot...
if so can i do the rooting another way that will work better
and if so wich method of rooting would be the best??
thanks for any help
no its not true
i use 2.2b with a2sd+overclocked on the smartass governor and its not rebooted yet.
have you tried doing a hard reset before reflashing the rom. it might be something else thats causing the issue
is the hard reset the same as factory reset???
soall was good on leedroid 2.2b for nearly a whole day then i got the bootloop i removed leedroid to standard froyo then tried defrost but didnt like it..
so i tried leedroid 2.2b but it froze when installing sence....
now im trying leedroid 2.2c and it stalls on the initial white htc boot screen..
i have managed to get leedroid 2.0a but cant get any higher versions working
i do a factory data reset each time from either main phone settings or from recovery if i cant get the phone to fully boot before flashing the rom each time....
was so happy with 2.2b untill it startied boot looping... now im thinking of givving up and useing the bog standard froyo just so the phone works
although it would be a big shame as leedroid was good when working :(
thanks...
finaly got leedroid 2.2b working again.... just hopeing thats it dosent cause the boot cycle again... has anywone eles tried 2.2c sucessfully??
no, lee said it was corrupted and messed up for everyone
hes replaced it with 2.2d
ive not updated yet as its too minor and ive been updating all week
ill wait till he has a bigger change log
great...
thanks for the info, thought i was doing something wrong or the file wasnt compleatly downloaded or something. got 2.2b back in and its been ok so far so might stick with it for now as im fed up of putting in all the settings and account logins :rolleyes:
