Root Unroot Galaxy Note
Well... Heres the deal. I want to unroot my phone now. Played around with the root and had my time. but got tired and blach blah. Ive spent the last couple of 5 hours trying to unroot it WITHOUT loosing my data......im not so happy about a 100% wipe....But I guess I am willing if its the last exit. Ive tried The video tutorial "http://androidforums.com/samsung-galaxy-note/504629-video-tutorial-how-unroot-galaxy-note-cursed4eva.html"
But it didn't work since my country isn't on the stock rom list. Ive tried these "one click unroot" wich is not helping... anyone care to help me out ?
Love you all
If you don't feel like helping me. Think of it as a guide to other members wanting to do the same thing
Use Odin to flash a stock rom. You can download the stock roms from xda.
After flash turn off the phone and boot into recovery. Wipe cache and factory reset. Reboot and you will be un rooted. Wipe prevents a boot loop.
By the way you don't have to have the exact same firmware. Any rom for the n7000 will work fine.
Mine was originally running a Hong Kong rom, now running a Euro rom.
If you see my guide for the S2 you can use my guide for Odin flashing.
ah so if I did the Odin easy root that didn't update my flash counter...the pda-odin-unroot will have to wipe my phone clean if I want to get rid of it?
Yes,
When you ODIN back to stock, you will trip your flash counter.
If this helps, I use all of Maxs tutorials at his site
Rootgalaxynote.com
His un rooting tutorial is awesome. has all links etc needed.
Just in case it helps.
