I want to unroot because I am returning my phone in 30 days and need to go back to stock. I have read over pages and pages of threads on how to unroot and thought I had every thing I needed but it didn't work.
Here are my stats:
supersonic evt-2 eng s-off
hboot-0.76.2000 (pc3610000)
microp-041f
touch panel-atmel224_16ab
radio-2.15.00.11.19
mar 30 2010 11:24:04
Calkulin's EViO 3 Rom v1.0
clockworkmod recovery v2.5.0.1
I think I used unrEVOked 3.2
Unhide to read all the steps if it helps fix this issue.
Looks like I got the PC36IMG.zip to flash and s-on now but now when I reboot I get stuck on the white htc EVO 4G screen and turns off after a minute or so. I wiped Dalvik cache and restarted but it gets to the white screen and then just turns off and the orange charge light flashes a few times and I have to drop the battery to be able to turn it back on. I removed the flash card and that didn't help.
<edit>
Just noticed I have HBOOT-2.10.0001 now.
<edit2>
I got a little further. I was able to flash the PC36IMG.zip again but now it keeps getting stuck at the Sprint 4G screen and just appears to reboot over and over.
Now I am getting a red ! in a triangle when trying to boot it. Tryint to get into recovery to wipe Dalvik cache but it won't let me.
Any suggestions?
Here are my stats:
microp-041f
radio-2.15.00.11.19
I flashed unrevoked-forever-son.zip about 12 times. The log file reports:
unrEVOked forever S-ON patch v1.3
Verifying system type...
Got device: @PID: 73,"SUPERSONIC_C"
Got radio version: 2.15.00.11.19
Checking system requirements...
Infinite loop duration: user-defined (good)
Brinell hardness: 35-45 (good)
Viscosity: SAE 20 or equivalent (good)
Voltages: Plate=+350VDC (good)
Filament=+12VDC (good)
Grid=-2.4VDC (good)
Operating environment: Yes (good)
Microcode verified CFC-free (good)
Syncing flash...
Verifying update...
Update successful.
unrevoked
The phone still says S-Off so I moved on.
I downloaded PC36IMG_SuperSonic_S_Sprint_WWE_3.70.651.1_Radio_2.15.00.11.19_NV_1.90_release_161482_signed.zip and get this:
Installing: PC36IMG_SuperSonic_S_Sprint_WWE_3.70.651.1_Radio_2.15.00.11.19_NV_1.90_release_161482_signed.zip
Finding update package...
Opening update package...
E:Can't open /sdcard/PC36IMG_SuperSonic_S_Sprint_WWE_3.70.651.1_Radio_2.15.00.11.19_NV_1.90_release_161482_signed.zip
(bad)
Installation aborted.
I downloaded two files from different sites and they both give that error.
I also downloaded a PC36IMG.zip from an XDA unrooting thread ([GUIDE] How to Unroot the EVO in 2 STEPS - xda-developers) and that loads in the bootloader screen and says:
Loading...[PC36IMG.zip]
Wrong zipped image
So I guess I got the wrong image file?
I downloaded and installed the Android SDK so I could run the 'fastboot oem writesecureflag 3' command but that errored out and didn't reset s-off to s-on.
So, while waiting to post this thread I decided to rename PC36IMG_SuperSonic...signed.zip to PC36IMG.zip and flash that and it looks to be installing.
Grid=-2.4VDC (good)
Syncing flash...
Verifying update...
Update successful.
unrevoked
(bad)
Wrong zipped image
<edit>
<edit2>
Any suggestions?
