Hi there all
Firstly this is a brilliant forum and one I'd only found sooner before I tried fiddling with my phone.
Anyway, long story short, I rooted my Galaxy S4 not too long ago, mainly to get rid of the damn pre-installed apps and also to have a tinker with some of those apps you can't get on an unrooted device. After doing so, successfully as Odin told me, I went about deleting some of the Samsung apps.
However a few hours after, I noticed my phone getting slower, and sometimes badly. Like unlocking after putting the pattern would take 10 or so seconds etc. Simple things also like screen rotation was not turning on or off when I wanted it to, and it kept dropping wifi network intermittently. Then the worst thing, I got a pop-up saying "unfortunately, samsung hub has stopped." Now this pop-up would go away the first few times after hitting OK, but then it would keep popping up, I mean within a second of pressing OK. And this makes the phone un-useable. Now I would like to unroot my phone, and bring it back to stock software so that I can use it (iPhone convert and I now hate iOS) however I am having trouble finding any firmware for the UK, my model number is the GT-i9505. I thought I found the right firmware and when using Odin it keeps coming up with FAIL! and then the phone gets stuck into download mode. I have factory reset the thing twice after backing up however the pop-up keeps killing me.
If you guys have any tips at all please let me know as currently I am using an iPhone 5 and I think someone will get badly hurt when I throw it out of the window because I hate it so much.
Thanks in advance.
PKPC
Thanks in advance.
PKPC
