hi, i'm new here, and prity mutch to android too, and already screwed up...
i have desire z, which i rooted (cyanogen wiki method) and flashed cyanogen 7 2.3
now having problem with screen, so will try to send for warranty, and wanted unroot it using:
theunlockr com/2010/12/01/how-to-unroot-the-t-mobile-g2-htc-vision
now as newbe, i downloaded stock bootloader wrom the link, and done ewerithing as said, after reboot i found that it's t mobile rom, and also that:
s -off,
and in simlock:
fat32 init ok
open mccmnc file fail open
cid file fail
downloaded rom manager few times as when i click on it it says:
you must root your phone for room manager to function. superuser was not found at "/system/bin/su"or"/system/xbin/su". use google to search instruction to root your phone.
all comands in cmw coming with:
an error ocured while attemptingto run previleged commands!
originaly was runing:
1.34.405.5
hbot 0.85.0005
mic0425
radio 26.03.02.26m
emmcboot
oct 11 2010
also i have backup of orriginal rom on sd and few backups of cm7, but can't load it without cmw
as when entering bootloader recovery i get red tiangle.
is anyone hawe an idea what steps to take to get it back to stock and su off without bricking it..?
found original rom at:
shipped-roms com/index.php?category=android&model=Vision
but how to load it? it comes as exe
and how to S-OFF propper for warranty?
and can you explain step by step as for noob
THANKS!!!!!!
p.s sorry for english grammar..
s -off,
and in simlock:
fat32 init ok
cid file fail
1.34.405.5
hbot 0.85.0005
mic0425
radio 26.03.02.26m
emmcboot
oct 11 2010
THANKS!!!!!!
